你要看,是不是这些蓝牙设备跑到其他网关去了。
你要看看是不是系统的问题,还是插件的问题,你按照这个排除一下
你试试这个ddnsto,这个穿透看看
您好,我今天才买回盒子,按教程基础参数设置完毕后,有2个问题:
请问如何解决,谢谢
第一个问题日志是:
日志详细信息( ERROR )
Logger: homeassistant.components.yeelight.config_flow
Source: components/yeelight/config_flow.py:258
Integration: Yeelight (documentation, issues)
First occurred: 24:51:50 (5 occurrences)
Last logged: 24:54:33
- Failed to get properties from 192.168.3.27: Failed to read from the socket at 192.168.3.27:55443: [Errno 111] Connect call failed (‘192.168.3.27’, 55443).
- Failed to get properties from 192.168.3.20: Failed to read from the socket at 192.168.3.20:55443: [Errno 111] Connect call failed (‘192.168.3.20’, 55443).
- Failed to get properties from 192.168.3.28: Failed to read from the socket at 192.168.3.28:55443: [Errno 111] Connect call failed (‘192.168.3.28’, 55443).
第二个问题是supervisor提示更新12.1,更新后显示
请问是否影响使用?
还有个问题 劳驾帮看看
Source: custom_components/hacs/system_health.py:22
Integration: HACS (documentation, issues)
First occurred: 01:14:15 (2 occurrences)
Last logged: 01:21:18
Error doing job: Task exception was never retrieved
Traceback (most recent call last): File “/usr/local/lib/python3.9/site-packages/aiogithubapi/client.py”, line 100, in async_call_api result = await self._session.request(**request_arguments) File “/usr/local/lib/python3.9/site-packages/aiohttp/client.py”, line 381, in _request raise RuntimeError(“Session is closed”) RuntimeError: Session is closed The above exception was the direct cause of the following exception: Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py”, line 26, in _handle_async_response await func(hass, connection, msg) File “/usr/src/homeassistant/homeassistant/components/system_health/init.py”, line 103, in handle_info await asyncio.gather( File “/usr/src/homeassistant/homeassistant/components/system_health/init.py”, line 68, in get_integration_info data = await registration.info_callback(hass) File “/config/custom_components/hacs/system_health.py”, line 22, in system_health_info response = await hacs.githubapi.rate_limit() File “/usr/local/lib/python3.9/site-packages/aiogithubapi/github.py”, line 184, in rate_limit response = await self._client.async_call_api(endpoint="/rate_limit", **kwargs) File “/usr/local/lib/python3.9/site-packages/aiogithubapi/client.py”, line 114, in async_call_api raise GitHubException( aiogithubapi.exceptions.GitHubException: Unexpected exception for ‘https://api.github.com/rate_limit’ with - Session is close
第一个是你的yeeligt灯接入没成功,第二个是正常提示。没有用官方的hassos的安装方法都会这么提示的。不影响正常使用。
你看hasc是不是有个限流提示?一般就是太多人用这个hacs程序了,它们没有自己的服务器,人多了就会限流。等一段时间就可以了
淘宝联系一下客户,让他安排技术给你清理一下用户权限。这是换了网络环境 触发了安全防护。
想把不要的设备排除不介入homekit的方案,请看这个教程最后几页
请问能否设置智趣盒子定时重启,不然最近老是出问题
- 你得看是不是ip变了,最近发现有些用小米路由的,ip每隔一段时间就会变化?
- 如果ip没有变,你浏览器输入ip:3000,截图给我们看看是不是homeassistant跪了。
请问各位大佬,萌新刚刚接触很一堆疑问网上找了教程按照教程操作步骤也没有安装成功.本人用的智趣盒子
昨天晚上才把米家接入系统导入home kit,于是开始折腾天气,日历.以及科沃斯扫地机器人,还想折腾天猫精灵有以下3个问题
1.科沃斯N9+怎么接入home assistant?在hacs里安装了点了
下载了也重启了集成里还是没有
2.Mac怎么进入
3.终端怎么进入
https://deebot.readthedocs.io/integrations/home-assistant/
第二个是教程文档,请参照操作即可。
英文看不懂,用谷歌浏览器翻译一下成中文就可以了
在Mac上连接samba
打开safari输入smb://ip,回车后出现输入用户名密码对话框,输入samba的用户名和密码即可
为什么不用webssh?
谢谢,问题2和3解决了.问题1我这边多截几张图上来.
