zigbee2mqtt:error 2020-03-30 17:07:25: Error while starting zigbee-herdsman
zigbee2mqtt:error 2020-03-30 17:07:25: Failed to start zigbee
zigbee2mqtt:error 2020-03-30 17:07:25: Exiting…
zigbee2mqtt:error 2020-03-30 17:07:25: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:71:23)
at Generator.throw ()
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:6:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.12.0-dev start: node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.12.0-dev start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2020-03-30T09_07_25_861Z-debug.log
