关了也还是不行 ,回家再试试!!!!!!!!!
那就不清楚了,可以试试重启一下网关
感谢分享~~~~~
请更新最新的网关程序
有没有好心人来个群晖docker的教程,我试了一下不成功。
上面说的地址其实是文件的目录
修改成你自己群辉docker里建立的文件夹
然后在群辉的docker里有个容器了在到目录下照图修改就可以了
尝试下变更信道。。。
干扰吗
更换路由器的信道,我试试看】,
在哪買的~能給個連接嗎?
我也遇到了类似问题
想创建多个zigbee2mqtt来支持接入多个z2m网关
创建第二个时就会报错
不知咋解
log如下:
Using ‘/app/data’ as data directory,
Creating configuration file…,
zigbee2mqtt@1.16.2 start /app,
node index.js,
Zigbee2MQTT:info 2020-12-11 12:08:36: Logging to console and directory: ‘/app/data/log/2020-12-11.12-08-35’ filename: log.txt,
Zigbee2MQTT:info 2020-12-11 12:08:36: Starting Zigbee2MQTT version 1.16.2 (commit #04c15f7),
Zigbee2MQTT:info 2020-12-11 12:08:36: Starting zigbee-herdsman (0.13.37),
Zigbee2MQTT:error 2020-12-11 12:08:36: Error while starting zigbee-herdsman,
Zigbee2MQTT:error 2020-12-11 12:08:36: Failed to start zigbee,
Zigbee2MQTT:error 2020-12-11 12:08:36: Exiting…,
Zigbee2MQTT:error 2020-12-11 12:08:36: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyACM0’,
at Znp. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32),
at Generator.next (),
at /app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71,
at new Promise (),
at __awaiter (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12),
at SerialPort. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49),
at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14),
at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12,
npm ERR! code ELIFECYCLE,
npm ERR! errno 1,
npm ERR! zigbee2mqtt@1.16.2 start:node index.js,
npm ERR! Exit status 1,,
npm ERR! Failed at the zigbee2mqtt@1.16.2 start script.,
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.,
npm ERR! A complete log of this run can be found in:,
npm ERR! /root/.npm/_logs/2020-12-11T12_08_36_812Z-debug.log,
node index.js,
Zigbee2MQTT:info 2020-12-11 12:11:23: Logging to console and directory: ‘/app/data/log/2020-12-11.12-11-22’ filename: log.txt,
Zigbee2MQTT:info 2020-12-11 12:11:23: Starting Zigbee2MQTT version 1.16.2 (commit #04c15f7),
Zigbee2MQTT:info 2020-12-11 12:11:23: Starting zigbee-herdsman (0.13.37),
Zigbee2MQTT:error 2020-12-11 12:11:42: Error while starting zigbee-herdsman,
Zigbee2MQTT:error 2020-12-11 12:11:42: Failed to start zigbee,
Zigbee2MQTT:error 2020-12-11 12:11:42: Exiting…,
Zigbee2MQTT:error 2020-12-11 12:11:42: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms),
at ZStackAdapter. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31),
at Generator.throw (),
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65),
npm ERR! errno 1,
npm ERR! /root/.npm/_logs/2020-12-11T12_11_42_562Z-debug.log,
node index.js,
Zigbee2MQTT:info 2020-12-11 12:14:02: Logging to console and directory: ‘/app/data/log/2020-12-11.12-14-01’ filename: log.txt,
Zigbee2MQTT:info 2020-12-11 12:14:02: Starting Zigbee2MQTT version 1.16.2 (commit #04c15f7),
Zigbee2MQTT:info 2020-12-11 12:14:02: Starting zigbee-herdsman (0.13.37),
Zigbee2MQTT:error 2020-12-11 12:14:21: Error while starting zigbee-herdsman,
Zigbee2MQTT:error 2020-12-11 12:14:21: Failed to start zigbee,
Zigbee2MQTT:error 2020-12-11 12:14:21: Exiting…,
Zigbee2MQTT:error 2020-12-11 12:14:21: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms),
npm ERR! errno 1,
npm ERR! /root/.npm/_logs/2020-12-11T12_14_22_022Z-debug.log,
同样问题 莫名其妙出现
检查config中 串口上的serial是不是对应的
这个问题是有两个程序在连接网关,所以请确保只有一个程序在连接网关。
