手动添加xiaomi_gateway3,xiaomi MIot,提示登陆失败,我在群晖登陆是正常的。
帐号与密码是正确的,我在群晖里同样登陆是帐号密码者正确的。能正常使用。
因为盒子HACS出现问题, 现在还没有解决,请看这看 hacs 手动安装最新版本后,集成说 错误 无法加载配置向导
所以我决定手动添加插件到 custom_components ,但在集成添加xiaomi_gateway3,xiaomi MIot,提示登陆失败, 是什么原因?
日志提示这样
Logger: custom_components.xiaomi_gateway3.core.xiaomi_cloud
Source: custom_components/xiaomi_gateway3/core/xiaomi_cloud.py:77
Integration: Xiaomi Gateway 3 (documentation, issues)
First occurred: 下午12:10:09 (6 occurrences)
Last logged: 下午2:47:57
Can’t login to Mi Cloud: Cannot connect to host account.xiaomi.com:443 ssl:default [Network unreachable]
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 969, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 1025, in create_connection
raise exceptions[0]
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 1010, in create_connection
sock = await self._connect_sock(
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 924, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/local/lib/python3.8/asyncio/selector_events.py”, line 496, in sock_connect
return await fut
File “/usr/local/lib/python3.8/asyncio/selector_events.py”, line 501, in _sock_connect
sock.connect(address)
OSError: [Errno 101] Network unreachable
The above exception was the direct cause of the following exception:
File “/config/custom_components/xiaomi_gateway3/core/xiaomi_cloud.py”, line 57, in login
payload = await self._login_step1()
File “/config/custom_components/xiaomi_gateway3/core/xiaomi_cloud.py”, line 77, in _login_step1
r = await self.session.get(
File “/usr/local/lib/python3.8/site-packages/aiohttp/client.py”, line 520, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 535, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 892, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 1051, in _create_direct_connection
raise last_exc
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 1020, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 975, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host account.xiaomi.com:443 ssl:default [Network unreachable]
Logger: custom_components.xiaomi_miot_raw.deps.xiaomi_cloud_new
Source: custom_components/xiaomi_miot_raw/deps/xiaomi_cloud_new.py:88
Integration: Xiaomi MIoT (documentation, issues)
First occurred: 下午2:36:18 (2 occurrences)
Last logged: 下午2:53:07
raise exceptions[0]
return await fut
File “/config/custom_components/xiaomi_miot_raw/deps/xiaomi_cloud_new.py”, line 59, in login
File “/config/custom_components/xiaomi_miot_raw/deps/xiaomi_cloud_new.py”, line 88, in _login_step1
raise last_exc
