您好,我目前遇到的问题是无法还原之前的备份,点击还原之后它不会显示断开连接之类的提示,按照教程清过数据依然没用。
提供一下你操作过程
设备没有吗????
就是先按照教程清除数据,然后点击备份页面,点击之前的备份跳出窗口,输入密码。然后窗口就没了,也没有什么变化
小白求问,请问怎么接入天猫精灵,并连接设备控制
另外,安装插件和更新会显示’HomeAssistantCore.update’ blocked from execution, system is not healthy
跟这个没关系
你还原先先清除旧的数据。你应该没有进行那一步。
所以你要按照教程的流程走,不要直接还原。
私信你了
今天要手动升级HACS,到了SAMBA一直不会弄,动了好多东西,然后现在HA瘫痪了
22-02-13 22:28:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-13 22:28:33 INFO (MainThread) [main] Setting up Supervisor
22-02-13 22:28:34 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-02-13 22:28:34 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-02-13 22:28:34 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface io.hass.os: The name io.hass.os was not provided by any .service files
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-02-13 22:28:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-02-13 22:28:35 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-02-13 22:28:35 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-02-13 22:28:35 INFO (MainThread) [supervisor.host.info] Updating local host information
22-02-13 22:28:35 INFO (MainThread) [supervisor.host.services] Updating service information
22-02-13 22:28:35 INFO (MainThread) [supervisor.host.network] Updating local network information
22-02-13 22:28:36 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-02-13 22:28:36 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-02-13 22:28:36 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
22-02-13 22:28:36 WARNING (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
22-02-13 22:28:36 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2021.12.0
22-02-13 22:28:36 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-02-13 22:28:38 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2021.12.0 - 172.30.32.5
22-02-13 22:28:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-dns with version 2021.06.0
22-02-13 22:28:38 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-02-13 22:28:40 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/aarch64-hassio-dns with version 2021.06.0 - 172.30.32.3
22-02-13 22:28:40 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-02-13 22:28:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-audio with version 2021.07.0
22-02-13 22:28:40 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-02-13 22:28:44 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio homeassistant/aarch64-hassio-audio with version 2021.07.0 - 172.30.32.4
22-02-13 22:28:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-observer with version 2021.10.0
22-02-13 22:28:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-multicast with version 2021.04.0
22-02-13 22:28:44 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-02-13 22:28:46 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/aarch64-hassio-multicast with version 2021.04.0 - Host
22-02-13 22:28:46 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-02-13 22:28:46 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-02-13 22:28:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemuarm-64-homeassistant with version 2022.2.6
22-02-13 22:28:46 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-02-13 22:28:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-02-13 22:28:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/18b3b383 repository
22-02-13 22:28:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-02-13 22:28:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository
22-02-13 22:28:51 INFO (MainThread) [supervisor.store] Loading add-ons from store: 69 all - 69 new - 0 remove
22-02-13 22:28:51 INFO (MainThread) [supervisor.addons] Found 7 installed add-ons
22-02-13 22:28:51 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ecaeb50e/aarch64-addon-knxd with version 0.4.2
22-02-13 22:28:51 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to zhujisheng/aarch64-addon-tunnel2local with version 1.0.10
22-02-13 22:28:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.3.3
22-02-13 22:28:51 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.0.1
22-02-13 22:28:51 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 9.5.1
22-02-13 22:28:51 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/node-red/aarch64 with version 11.0.0
22-02-13 22:28:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.23.0-1
22-02-13 22:28:51 INFO (MainThread) [supervisor.backups.manager] Found 12 backup files
22-02-13 22:28:51 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
22-02-13 22:28:51 INFO (MainThread) [supervisor.ingress] Loaded 4 ingress sessions
22-02-13 22:28:51 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-02-13 22:28:51 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-02-13 22:28:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-02-13 22:28:51 WARNING (MainThread) [supervisor.resolution.evaluations.base] OS-Agent is not correctly working (more-info: https://www.home-assistant.io/more-info/unsupported/os_agent)
22-02-13 22:28:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-13 22:28:51 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - CoreState.SETUP
22-02-13 22:28:51 INFO (MainThread) [main] Running Supervisor
22-02-13 22:28:51 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
22-02-13 22:28:51 INFO (MainThread) [supervisor.jobs] ‘OSManager.mark_healthy’ blocked from execution, no Home Assistant OS available
22-02-13 22:28:51 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
22-02-13 22:28:51 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SYSTEM’ starting 1 add-ons
22-02-13 22:28:51 WARNING (MainThread) [supervisor.addons.options] Option ‘anonymous’ does not exist in the schema for Mosquitto broker (core_mosquitto)
22-02-13 22:28:51 WARNING (SyncWorker_0) [supervisor.addons.options] Option ‘anonymous’ does not exist in the schema for Mosquitto broker (core_mosquitto)
22-02-13 22:28:54 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.0.1
22-02-13 22:28:59 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SERVICES’ starting 1 add-ons
22-02-13 22:28:59 WARNING (MainThread) [supervisor.addons.options] Option ‘interface’ does not exist in the schema for Samba share (core_samba)
22-02-13 22:28:59 WARNING (SyncWorker_6) [supervisor.addons.options] Option ‘interface’ does not exist in the schema for Samba share (core_samba)
22-02-13 22:29:00 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 9.5.1
22-02-13 22:29:05 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from core_samba
22-02-13 22:29:05 INFO (MainThread) [supervisor.core] Start Home Assistant Core
22-02-13 22:29:06 INFO (SyncWorker_0) [supervisor.docker.interface] Starting homeassistant
22-02-13 22:29:06 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-02-13 22:29:09 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
22-02-13 22:30:19 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
22-02-13 22:30:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-13 22:30:36 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-02-13 22:39:38 INFO (MainThread) [supervisor.backups.manager] Found 12 backup files
22-02-13 22:39:39 INFO (MainThread) [supervisor.backups.manager] Found 12 backup files
22-02-13 22:39:54 WARNING (MainThread) [supervisor.addons.options] Option ‘interface’ does not exist in the schema for Samba share (core_samba)
22-02-13 22:45:24 WARNING (MainThread) [supervisor.addons.options] Option ‘require_ssl’ does not exist in the schema for Node-RED (a0d7b954_nodered)
22-02-13 22:45:29 WARNING (MainThread) [supervisor.addons.options] Option ‘require_ssl’ does not exist in the schema for Node-RED (a0d7b954_nodered)
22-02-13 22:46:10 INFO (MainThread) [supervisor.backups.manager] Found 12 backup files
22-02-13 22:46:19 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
22-02-13 22:46:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-13 22:46:19 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-02-13 22:46:23 WARNING (MainThread) [supervisor.jobs] ‘Supervisor.restart’ blocked from execution, system is not running - CoreState.STARTUP
22-02-13 22:46:35 WARNING (MainThread) [supervisor.jobs] ‘Supervisor.restart’ blocked from execution, system is not running - CoreState.STARTUP
22-02-13 22:46:47 WARNING (MainThread) [supervisor.addons.options] Option ‘interface’ does not exist in the schema for Samba share (core_samba)
22-02-13 22:48:49 INFO (MainThread) [supervisor.backups.manager] Found 12 backup files
就是按照教程走的。试了很多遍都这样,备份文件是找客服要的
萤石的摄像头如何接入homekit,谢谢
逐步截图,看看你怎么弄的。你这样说看不多过程,没有啥有效信息。
以后提供信息,要截图,别贴一堆代码上来。截图可以看到里面红色提示的。
你重新还原试试吧。
博联直接有官方的插件啊。
按照官方插件执行就可以了。
英文看不懂,用谷歌浏览器翻译成中文即可。
官方博联支持的设备少,找的这个插件支持的多,但是没看懂如何使用
