2021-07-20 20:04:10 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miio_fan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration xiaomi_remote which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xiaomi_miio_plug which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration colorfulclouds which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration phicomm_dc1 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration midea which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_7) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_9) [homeassistant.loader] We found a custom integration icloud3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration molohub which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration moguhome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_miio_philipslight which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration miio_yeelink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_10) [homeassistant.loader] We found a custom integration xiaomi_miio_airpurifier which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration xiaomi_miio_airconditioningcompanion which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_gateway3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration health_pot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_13) [homeassistant.loader] We found a custom integration miheater which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 ERROR (SyncWorker_13) [homeassistant.loader] The custom integration ‘miheater’ does not have a valid version key (None) in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-07-20 20:04:10 WARNING (SyncWorker_12) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration midea_ac which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration airnut which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration xiaomi_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_14) [homeassistant.loader] We found a custom integration ewelink_climate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_7) [homeassistant.loader] We found a custom integration viomise which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_11) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 WARNING (SyncWorker_10) [homeassistant.loader] We found a custom integration zigbee2mqtt_networkmap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 20:04:10 ERROR (SyncWorker_10) [homeassistant.loader] The custom integration ‘zigbee2mqtt_networkmap’ does not have a valid version key (None) in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-07-20 20:04:21 ERROR (MainThread) [homeassistant.setup] Setup failed for lifesmart: Integration not found.
2021-07-20 20:04:25 ERROR (MainThread) [custom_components.hacs] HttpStatusCode.UNAUTHORIZED
2021-07-20 20:04:25 CRITICAL (MainThread) [custom_components.hacs] Your GitHub token is not valid
2021-07-20 20:04:25 ERROR (MainThread) [custom_components.hacs] HACS is disabled - HacsDisabledReason.INVALID_TOKEN
2021-07-20 20:10:31 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py”, line 25, in _handle_async_response
await func(hass, connection, msg)
File “/usr/src/homeassistant/homeassistant/components/system_health/init.py”, line 104, in handle_info
await asyncio.gather(
File “/usr/src/homeassistant/homeassistant/components/system_health/init.py”, line 69, in get_integration_info
data = await registration.info_callback(hass)
File “/config/custom_components/hacs/system_health.py”, line 24, in system_health_info
rate_limit = await client.github.get_rate_limit()
File “/usr/local/lib/python3.8/site-packages/aiogithubapi/github.py”, line 102, in get_rate_limit
await self.client.get(endpoint=_endpoint)
File “/usr/local/lib/python3.8/site-packages/aiogithubapi/client.py”, line 49, in get
response = await async_call_api(
File “/usr/local/lib/python3.8/site-packages/backoff/_async.py”, line 133, in retry
ret = await target(*args, **kwargs)
File “/usr/local/lib/python3.8/site-packages/aiogithubapi/helpers.py”, line 79, in async_call_api
raise AIOGitHubAPIAuthenticationException(HttpStatusCode.UNAUTHORIZED)
aiogithubapi.common.exceptions.AIOGitHubAPIAuthenticationException: HttpStatusCode.UNAUTHORIZED
