前言
软硬件支持
- nodered;
- 需要用到的节点:
- node-red-contrib-wfwatch
- node-red-contrib-image-output
- node-red-contrib-http-request
- node-red-contrib-bizwechat
实现步骤:
- 创建应用
例:https://aip.baidubce.com/rest/2.0/image-classify/v1/animal?access_token=获取到的access_token
- 图片的获取
自行查看摄像头抓图地址
由于我的摄像头是EASYN,暂时没有找到抓图地址,并且使用群辉的surveillance station抓图也暂时没有成功,所以我使用的方法是靠Easyn摄像头自动侦测移动拍照,照片通过保存到指定的FTP服务器文件夹(FTP服务器我使用的是群辉,下次补充过程),使用wfwatch节点监控FTP文件夹是否有新图片产生,对新生成的图片进行识别并推送结果。
高级推送参考贴或者论坛搜索相关帖子
百度api识别动物.json (16.6 KB)
"id": "211f2157.c10eae",
"type": "tab",
"label": "流程1",
"disabled": false,
"info": ""
"id": "6eb2e72a.e5c7a8",
"type": "function",
"z": "211f2157.c10eae",
"name": "获取access_token",
"func": "msg.headers = {\n \"Content-Type\" : \"application/x-www-form-urlencoded\"\n}\nmsg.payload = {\n \"grant_type\" : \"client_credentials\",\n \"client_id\" : \"你的API Key\",\n \"client_secret\" : \"你的Secret Key\"\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 390,
"y": 100,
"wires": [
"91a3a8e.669c358"
"id": "91a3a8e.669c358",
"type": "http request",
"name": "获取access_tkoen",
"method": "POST",
"ret": "obj",
"paytoqs": false,
"url": "https://aip.baidubce.com/oauth/2.0/token",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 610,
"y": 100,
"wires": [
"ec5a1317.f9a0b"
"id": "ec5a1317.f9a0b",
"type": "function",
"name": "保存access_token",
"func": "flow.set('access_token', msg.payload.access_token); //将access_token储存\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 810,
"y": 100,
"wires": [
"4ffabf56.25cde"
"id": "4ffabf56.25cde",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 990,
"y": 100,
"wires": []
"id": "2d61931e.557b9c",
"type": "file in",
"name": "",
"filename": "",
"format": "",
"chunk": false,
"sendError": false,
"encoding": "binary",
"x": 570,
"y": 260,
"wires": [
"e7b5e77d.3d4798",
"71392818.cfaf28"
"id": "7446262e.463018",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 280,
"y": 260,
"wires": [
"2fde816d.43eace"
"id": "e7b5e77d.3d4798",
"type": "base64",
"name": "",
"action": "",
"property": "payload",
"x": 740,
"y": 260,
"wires": [
"4aa015b3.5c9a2c"
"id": "4aa015b3.5c9a2c",
"type": "function",
"name": "动物识别",
"func": "msg.headers = {\n \"Content-Type\" : \"application/x-www-form-urlencoded\"\n}\nmsg.url = `https://aip.baidubce.com/rest/2.0/image-classify/v1/animal?access_token=${flow.get('access_token')}`;\nmsg.payload = {\n image:msg.payload, //图片Base64编码\n baike_num:5 //返回百科信息的结果数量\n}\n\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"x": 920,
"y": 260,
"wires": [
"d216d0fe.34d28"
"id": "d216d0fe.34d28",
"name": "识别请求",
"method": "POST",
"ret": "obj",
"paytoqs": false,
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 1080,
"y": 260,
"wires": [
"af0fb26f.c366e",
"fb7ba407.33bbb8"
"id": "af0fb26f.c366e",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"x": 1270,
"y": 200,
"wires": []
"id": "71392818.cfaf28",
"type": "image",
"name": "",
"width": "1080",
"data": "payload",
"dataType": "msg",
"thumbnail": false,
"x": 760,
"y": 200,
"wires": []
"id": "5659c311.8812fc",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 390,
"y": 40,
"wires": []
"id": "c903e9dc.fd1ef8",
"type": "wfwatch",
"folder": "photo",
"x": 70,
"y": 100,
"wires": [
"d732c2a1.f1d38"
"id": "4ed5eba3.d047f4",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 570,
"y": 200,
"wires": []
"id": "d732c2a1.f1d38",
"type": "switch",
"name": "",
"property": "payload.changeType",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "delete",
"vt": "str"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 210,
"y": 100,
"wires": [
"5659c311.8812fc"
"7446262e.463018",
"6eb2e72a.e5c7a8",
"5659c311.8812fc"
"id": "2fde816d.43eace",
"type": "change",
"name": "文件路径",
"rules": [
"t": "move",
"p": "msg.payload.filePath",
"pt": "msg",
"to": "msg.filename",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 420,
"y": 260,
"wires": [
"2d61931e.557b9c",
"4ed5eba3.d047f4"
"id": "fb7ba407.33bbb8",
"type": "link out",
"name": "",
"links": [
"7c24c551.86efdc"
"x": 1215,
"y": 260,
"wires": []
"id": "7c24c551.86efdc",
"type": "link in",
"name": "",
"links": [
"fb7ba407.33bbb8"
"x": 75,
"y": 360,
"wires": [
"87349201.502d3"
"id": "87349201.502d3",
"type": "function",
"name": "判断是猫是狗",
"func": "var len = msg.payload.result.length;\nfor(var i = 0;i<len;i++){\n var nam = msg.payload.result[i].name;\n if(nam.indexOf(\"猫\")!=-1){\n return [msg,null,null];\n break;\n }\n else if(nam.indexOf(\"狗\")!=-1){\n return [null,msg,null];\n break;\n }\n}\nreturn [null,null,msg];",
"outputs": 3,
"noerr": 0,
"x": 250,
"y": 360,
"wires": [
"e84be81c.243138"
"147eac4.3574f54"
"9fd9d17d.e0e66"
"id": "febc3c0b.5971a",
"type": "bizwechat-upload",
"name": "",
"bizwechat": "dcc952ef.2d506",
"x": 740,
"y": 340,
"wires": [
"c6b54f7e.b505c"
"id": "c6b54f7e.b505c",
"type": "function",
"name": "小猫来了",
"func": "msg.payload = {\n \"touser\" : \"@all\",\n \"msgtype\" : \"mpnews\",\n \"mpnews\" : {\n \"articles\":[\n {\n \"title\": \"小猫来啦\", \n \"thumb_media_id\": `${msg.payload.media_id}`,\n //\"author\": \"Author\",\n //\"content_source_url\": \"URL\",\n \"content\": `${msg.payload.media_id}`,\n \"digest\": \"小猫咪,喵喵喵\"\n }\n ]\n },\n \"safe\":0\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 920,
"y": 340,
"wires": [
"d67d9ddd.13679"
"id": "d67d9ddd.13679",
"type": "bizwechat-push",
"name": "",
"x": 1120,
"y": 340,
"wires": [
"51df7a82.dd6164"
"id": "51df7a82.dd6164",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1310,
"y": 340,
"wires": []
"id": "68d8ffdf.8bdd8",
"type": "function",
"name": "设定上传",
"func": "msg.type = \"image\"; //上传临时文件必须要的\nmsg.filename = msg.filename; //文件名可以随便写\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 560,
"y": 340,
"wires": [
"febc3c0b.5971a",
"88976cf9.bb4bd"
"id": "18714c43.d539b4",
"name": "",
"x": 740,
"y": 400,
"wires": [
"ea9f9f34.818a5"
"id": "ea9f9f34.818a5",
"type": "function",
"name": "狗来了",
"func": "msg.payload = {\n \"touser\" : \"@all\",\n \"msgtype\" : \"mpnews\",\n \"mpnews\" : {\n \"articles\":[\n {\n \"title\": \"狗来了\", \n \"thumb_media_id\": `${msg.payload.media_id}`,\n //\"author\": \"Author\",\n //\"content_source_url\": \"URL\",\n \"content\": `狗来了狗来了`,\n \"digest\": \"狗来了狗来了\"\n }\n ]\n },\n \"safe\":0\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 910,
"y": 400,
"wires": [
"ccced67c.7429a8"
"id": "ccced67c.7429a8",
"name": "",
"x": 1120,
"y": 400,
"wires": [
"40ca7ccd.f582b4"
"id": "40ca7ccd.f582b4",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1310,
"y": 400,
"wires": []
"id": "1bda1130.a220ff",
"type": "function",
"name": "设定上传",
"outputs": 1,
"noerr": 0,
"x": 560,
"y": 400,
"wires": [
"18714c43.d539b4"
"id": "88976cf9.bb4bd",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 730,
"y": 520,
"wires": []
"id": "e84be81c.243138",
"type": "file in",
"name": "",
"filename": "",
"format": "",
"chunk": false,
"sendError": false,
"x": 430,
"y": 340,
"wires": [
"68d8ffdf.8bdd8"
"id": "147eac4.3574f54",
"type": "file in",
"name": "",
"filename": "",
"format": "",
"chunk": false,
"sendError": false,
"x": 430,
"y": 400,
"wires": [
"1bda1130.a220ff"
"id": "33867db5.e09152",
"name": "",
"x": 740,
"y": 460,
"wires": [
"6b2f12b4.720a3c"
"id": "6b2f12b4.720a3c",
"type": "function",
"name": "误报",
"func": "msg.payload = {\n \"touser\" : \"@all\",\n \"msgtype\" : \"mpnews\",\n \"mpnews\" : {\n \"articles\":[\n {\n \"title\": \"误报\", \n \"thumb_media_id\": `${msg.payload.media_id}`,\n //\"author\": \"Author\",\n //\"content_source_url\": \"URL\",\n \"content\": `aaa`,\n \"digest\": \"别紧张\"\n }\n ]\n },\n \"safe\":0\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 910,
"y": 460,
"wires": [
"61626474.34ec0c"
"id": "61626474.34ec0c",
"name": "",
"x": 1120,
"y": 460,
"wires": [
"ae153b49.027c28"
"id": "ae153b49.027c28",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1310,
"y": 460,
"wires": []
"id": "8f0c9a81.6837b8",
"type": "function",
"name": "设定上传",
"outputs": 1,
"noerr": 0,
"x": 560,
"y": 460,
"wires": [
"33867db5.e09152"
"id": "9fd9d17d.e0e66",
"type": "file in",
"name": "",
"filename": "",
"format": "",
"chunk": false,
"sendError": false,
"x": 430,
"y": 460,
"wires": [
"8f0c9a81.6837b8"
"id": "dcc952ef.2d506",
"type": "bizwechat-configurator",
"z": "",
"name": "导出专用",
"port": "",
"corpid": "",
"agentid": "",
"corpsecret": "",
"url": "",
"token": "",
"aeskey": "",
"client_id": "",
"client_secret": ""
上图把狗识别出猫是因为返回结果里没有狗这个字,而出现了一次猫这个字导致的。所以需要经过更多的数据采集来完善判断。
