电热水壶和消毒碗柜都同时插在一个可即时更新功率的插座上.
如何来实现水壶烧完水, 消毒碗柜消毒完碗时TTS提醒呢?
前置需求
- 可查询即时功率的插座, 本例用的是米家智能插座带usb口的增强版
- 配置好InfluxDB数据库, 可参考妖神教程](https://bbs.iobroker.cn/t/topic/559/1)
- TTS
原理简述
- 当功率从较高状态下, 下降为1w, 可判断为 消毒或水壶完成了消毒或烧水
- 查询60秒前到现在,功率的最大值, 如果较高就是烧完水, 如果较低就是消毒完成
安装InfluxDB节点
配置InfluxDB节点
node-red 流
{"id":"74d482d0.8bc0fc","type":"ioBroker in","z":"8d3e5e26.c7e32","name":"米家恒温水壶插座功率","topic":"miio.0.devices.91908807.loadPower","payloadType":"object","onlyack":"","func":"all","gap":"","x":140,"y":2020,"wires":"3530abf6.bdc574","da772e8d.34c1c"]]},{"id":"e8247e62.61a66","type":"debug","z":"8d3e5e26.c7e32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":1920,"wires":]},{"id":"da772e8d.34c1c","type":"switch","z":"8d3e5e26.c7e32","name":"过滤非即时更新的消息","property":"timestamp","propertyType":"msg","rules":{"t":"eq","v":"lastchange","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":2020,"wires":"aa19a930.eba7d8"]]},{"id":"aa19a930.eba7d8","type":"switch","z":"8d3e5e26.c7e32","name":"","property":"payload.val","propertyType":"msg","rules":{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":2020,"wires":"e8247e62.61a66","2cce0a35.b7b266"]]},{"id":"65d01e2c.1772f","type":"function","z":"8d3e5e26.c7e32","name":"烧水输出TTS内容","func":"msg.payload = `米家恒温水壶烧水程序已完成`;\nreturn msg;","outputs":1,"noerr":0,"x":1690,"y":2000,"wires":]]},{"id":"3530abf6.bdc574","type":"debug","z":"8d3e5e26.c7e32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":420,"y":2100,"wires":]},{"id":"38cfaa7.d541056","type":"comment","z":"8d3e5e26.c7e32","name":"米家恒温水壶烧水提醒","info":"","x":140,"y":1960,"wires":]},{"id":"2cce0a35.b7b266","type":"influxdb in","z":"8d3e5e26.c7e32","influxdb":"224365dd.1bf8da","name":"查询一小时内插座的最大功率","query":"SELECT max(*) FROM \"miio.0.devices.91908807.loadPower\" WHERE time > now() - 60s","rawOutput":false,"precision":"","retentionPolicy":"","x":860,"y":2020,"wires":"2448c312.fcd91c","b3de142c.4d36e8"]]},{"id":"81960f5e.283ab","type":"debug","z":"8d3e5e26.c7e32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1330,"y":2180,"wires":]},{"id":"2448c312.fcd91c","type":"moment","z":"8d3e5e26.c7e32","name":"转换时间格式","topic":"","input":"payload[0].time","inputType":"msg","inTz":"Asia/Shanghai","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD HH:mm","locale":"C","output":"time","outputType":"msg","outTz":"Asia/Shanghai","x":1120,"y":2020,"wires":"81960f5e.283ab","b3dbb248.e6817"]]},{"id":"b3de142c.4d36e8","type":"debug","z":"8d3e5e26.c7e32","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1070,"y":2180,"wires":]},{"id":"b3dbb248.e6817","type":"switch","z":"8d3e5e26.c7e32","name":"功率最大值判断机器","property":"payload[0].max_value","propertyType":"msg","rules":{"t":"gte","v":"800","vt":"num"},{"t":"lt","v":"800","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1380,"y":2020,"wires":"65d01e2c.1772f"],"5c68e6b9.7e18f8"]]},{"id":"5c68e6b9.7e18f8","type":"function","z":"8d3e5e26.c7e32","name":"消毒完成输出TTS内容","func":"msg.payload = `康宝消毒碗柜消毒程序已完成`;\nreturn msg;","outputs":1,"noerr":0,"x":1680,"y":2060,"wires":]]},{"id":"224365dd.1bf8da","type":"influxdb","z":"","hostname":"192.168.2.101","port":"8086","protocol":"http","database":"iobroker","name":"","usetls":false,"tls":""}]
大神厉害,学习了很多。我学习你的这个流程,搞了一个厨房关灯流程。就是根据湿度降低的差值,判断是否做饭完成。正在试验中。谢谢你的分享
