在我们使用Home Assistant的过程中,往往希望获取天气数据,而互联网天气,成为了第一种选择,本文就告诉大家如何集成互联网天气,这次我们使用HeWeather
集成
按照如下命令安装:
cd /etc/hass
cd custom_components
git clone https://github.com/morestart/HeWeather
修改/etc/hass/configuration.yaml:
sensor:
- platform: HeWeather
city: "佛山"
appkey: <appkey>
options:
- fl
- tmp
- cond_txt
- wind_spd
- hum
- pcpn
- pres
- vis
- wind_sc
- aqi
- main
- qlty
- pm10
- pm25
- comf
- cw
- drsg
- flu
- sport
- trav
- uv
- wind_dir
- tmp_max
- tmp_min
- pop
使用以下命令重启hass:
systemctl restart hass
设置仪表盘
通过配置->lovelace仪表盘->添加仪表盘添加天气仪表盘,进入天气选项卡,使用如下仪表盘配置:
background: var(--background-image)
- title: 天气
path: weather
icon: mdi:weather-cloudy
badges: []
cards:
- type: glance
entities:
- sensor.zhu_yao_wu_ran_wu
- sensor.chu_xing_zhi_shu
- sensor.tian_qi_zhuang_tai
- sensor.gan_mou_zhi_shu
- sensor.xi_che_zhi_shu
- sensor.zi_wai_xian_zhi_shu
- sensor.chuan_yi_zhi_shu
- sensor.kong_qi_zhi_liang
- sensor.shu_gua_du_zhi_shu
- type: sensor
entity: sensor.da_qi_ya
graph: line
detail: 2
- type: sensor
entity: sensor.feng_su
graph: line
detail: 2
- type: gauge
entity: sensor.jiang_shui_gai_lu
- type: sensor
entity: sensor.jiang_shui_liang
graph: line
detail: 2
- type: sensor
entity: sensor.jin_ri_zui_di_wen_du
graph: line
detail: 2
- type: sensor
entity: sensor.jin_ri_zui_gao_wen_du
graph: line
detail: 2
- type: sensor
entity: sensor.kong_qi_zhi_liang_zhi_shu
graph: line
detail: 2
- type: sensor
entity: sensor.neng_jian_du
graph: line
detail: 2
- type: gauge
entity: sensor.shi_shi_shi_wai_shi_du
- type: sensor
entity: sensor.shi_shi_shi_wai_wen_du
graph: line
detail: 2
- type: sensor
entity: sensor.shi_shi_ti_gan_wen_du
graph: line
detail: 2
- type: sensor
entity: sensor.pm10
graph: line
detail: 2
- type: sensor
entity: sensor.pm2_5
graph: line
detail: 2
title: 天气
https://web.res.qhjack.cn/2021/06/25/bf481a50e5f4ae1884aebc588c2b353d
配置NODERED
对于使用了NODE-RED和小爱对接的,可以导入以下仪表盘:
"id": "693cee39.d45af",
"type": "tab",
"label": "温度",
"disabled": false,
"info": ""
"id": "f18452d2.92aec",
"type": "server-state-changed",
"z": "693cee39.d45af",
"name": "湿度",
"server": "3c87f99d.1fa9b6",
"version": 3,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.shi_shi_shi_wai_shi_du",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 170,
"y": 160,
"wires": [
"1d1653b7.db4eec"
"id": "8659849e.4aefe",
"name": "温度",
"version": 3,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.shi_shi_shi_wai_wen_du",
"haltifstate": "",
"outputs": 1,
"for": 0,
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 170,
"y": 240,
"wires": [
"1d1653b7.db4eec"
"id": "1d1653b7.db4eec",
"type": "api-current-state",
"name": "查询温度",
"version": 2,
"outputs": 1,
"halt_if": "",
"entity_id": "sensor.shi_shi_shi_wai_wen_du",
"blockInputOverrides": false,
"value": "",
"property": "data",
"value": "",
"valueType": "entity"
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 420,
"y": 200,
"wires": [
"47d64f14.57fbe8"
"id": "47d64f14.57fbe8",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "temp",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 650,
"y": 200,
"wires": [
"82e1cc.a13f4638"
"id": "82e1cc.a13f4638",
"name": "查询湿度",
"version": 2,
"outputs": 1,
"halt_if": "",
"entity_id": "sensor.shi_shi_shi_wai_shi_du",
"value": "",
"property": "data",
"value": "",
"x": 860,
"y": 200,
"wires": [
"311016f7.c10e4a"
"id": "311016f7.c10e4a",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "humidity",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1090,
"y": 200,
"wires": [
"8fbfbf31.dc93d8"
"id": "d49bc6b.0863cb8",
"type": "template",
"name": "设置数据格式",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "#{{ temp }}#{{ humidity }}#1#{{ pm2.5 }}#{{ qiya }}#",
"output": "str",
"x": 440,
"y": 460,
"wires": [
"57608fc0.8cb2e"
"id": "57608fc0.8cb2e",
"type": "mqtt out",
"name": "上传数据",
"topic": "temp004",
"qos": "0",
"retain": "false",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "dd5ff2b3.26398",
"x": 740,
"y": 460,
"wires": []
"id": "8544faf3.aa2478",
"name": "PM2.5",
"version": 3,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.pm2_5",
"haltifstate": "",
"outputs": 1,
"for": 0,
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 170,
"y": 340,
"wires": [
"1d1653b7.db4eec"
"id": "8fbfbf31.dc93d8",
"name": "查询PM2.5",
"version": 2,
"outputs": 1,
"halt_if": "",
"entity_id": "sensor.pm2_5",
"value": "",
"property": "data",
"value": "",
"x": 430,
"y": 340,
"wires": [
"6bff3829.08cf5"
"id": "6bff3829.08cf5",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "pm2.5",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 660,
"y": 340,
"wires": [
"24f97475.de2e9c"
"id": "24f97475.de2e9c",
"name": "查询气压",
"version": 2,
"outputs": 1,
"halt_if": "",
"entity_id": "sensor.da_qi_ya",
"value": "",
"property": "data",
"value": "",
"x": 900,
"y": 340,
"wires": [
"be856cb.b3c469"
"id": "be856cb.b3c469",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "qiya",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1120,
"y": 340,
"wires": [
"d49bc6b.0863cb8"
"id": "a030aed2.d9ba78",
"name": "大气压",
"version": 3,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.da_qi_ya",
"haltifstate": "",
"outputs": 1,
"for": 0,
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 170,
"y": 440,
"wires": [
"1d1653b7.db4eec"
"id": "3c87f99d.1fa9b6",
"type": "server",
"name": "Home Assistant",
"version": 1,
"legacy": false,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true
"id": "dd5ff2b3.26398",
"type": "mqtt-broker",
"name": "Remote MQTT",
"broker": "bemfa.com",
"port": "9501",
"clientid": "7ca62f668da56fafbbafa04dbfe42a5f",
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
流程效果图:
https://web.res.qhjack.cn/2021/06/25/5d227244c6ff23d80189fe1f0091a5fd
