npm ERR! /root/.npm/_logs/2021-05-21T05_09_20_526Z-debug.log
[13:09:21] INFO: Handing over control to Zigbee2mqtt Core …
zigbee2mqtt@1.18.3 start /app
node index.js
Zigbee2MQTT:error 2021-05-21 13:09:47: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-05-21 13:09:47: Failed to start zigbee
Zigbee2MQTT:error 2021-05-21 13:09:47: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-05-21 13:09:47: Exiting…
Zigbee2MQTT:error 2021-05-21 13:09:47: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
at Generator.throw ()
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.18.3 start: node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.18.3 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2021-05-21T05_09_47_956Z-debug.log
[13:09:48] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
