2021.6.0ha版本改了标准,molo要加个版本号,晚些我有电脑了,上传更新版本号教程。
通过samba进入config,再进入custom_components,找到molohub文件夹,把附件的文件解压得到的manifest.json文件,替换到molohub文件夹,然后重启homeassistant,就可以了。
manifest.json.zip (662 字节)
感谢大神,已经完美解决
继续发现问题,哈哈,后面我都在新版本完善。
哈哈,好的,有问题我立马提问
看我上面发的方法能不能解决
大神,我用这个命令安装了蓝牙软件包 aptitude install bluetooth bluez-utils bluez-compat 但是还是显示蓝牙失败
日志:
Logger: homeassistant.components.bluetooth_tracker.device_tracker
Source: components/bluetooth_tracker/device_tracker.py:63
Integration: bluetooth_tracker (documentation, issues)
First occurred: 13:19:02 (6 occurrences)
Last logged: 13:21:31
Error looking up Bluetooth device
File “/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py”, line 30, in discover_devices
results = _bt.hci_inquiry (sock, duration=duration, flush_cache=True,
_bluetooth.error: (95, ‘Not supported’)
During handling of the above exception, another exception occurred:
File “/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py”, line 156, in perform_bluetooth_update
devices = await hass.async_add_executor_job(discover_devices, device_id)
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
result = self.fn(*self.args, **self.kwargs)
File “/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py”, line 63, in discover_devices
result = bluetooth.discover_devices(
File “/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py”, line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
我的HACS突然不能用了 显示我的token错误,但是在集成里集成HACS,不是不用输入token吗,我尝试在yaml里配置token也还是不行
Logger: custom_components.hacs
Source: custom_components/hacs/base.py:123
Integration: HACS (documentation, issues)
First occurred: 下午3:27:37 (1 occurrences)
Last logged: 下午3:27:37
HACS is disabled - HacsDisabledReason.INVALID_TOKEN
1.删除config里面的 custom_components 和 .storage 两个文件夹里面中的 HACS文件夹;
2.手动到github下载最新版本并在“custom_components/hacs”文件夹下解压;
3.重启homeassistant;
4.尝试按通过 集成 添加hacs。
OpenTherm gateway 插件应该是连接壁挂炉的,这个插件要求输入名称、URL、ID,这个ID是什么呢?
买了个易微联的 Sonoff RF Bridge 433设备,也添加到HA了,怎么才能添加这个433的发射命令,希望大神出个教程啊
易微联出了射频遥控器吗?我还没有用过哦,我晚些看看
今天下午重新安装了“ [homeassistan消费者全面定制版20210415”的固件,服务都启动了。
1.升级到最新的版本的homeassistant,重启的那里如果不行,就是去supervisor,找到homeassistant core里面重启
那你清理一下浏览器的缓存,重新登录管理界面。
