我倒希望是,但是一开始是可以正常使用的,ddns是在线的。tp的根本用不着教程,登录账号就行。中秋之前至少用114的DNS还能解析,现在完全不行了,已经瘫了,早知道会这么坑,也就不会买TP的路由器了。
改变了token之后 重启后不见的
你把你的改动的信息截图上来,应该是你整错了。
这个提示你改错格式,出错了提示。
zigbee2mqtt页面无法登录,如下图:
实际是已经启动了的。
下面是配置:
还有日志:
Zigbee2MQTT:error 2021-09-26 16:39:05: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:05: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:05: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:05: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:05: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
at SerialPort. (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
[16:39:06] INFO: Handing over control to Zigbee2mqtt Core …
zigbee2mqtt@1.21.1 start
node index.js
Zigbee2MQTT:error 2021-09-26 16:39:15: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:15: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:15: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:15: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:15: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:39:16] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:39:24: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:24: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:24: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:24: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:25: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:39:25] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:39:34: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:34: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:34: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:34: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:34: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:39:35] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:39:44: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:44: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:44: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:44: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:44: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:39:45] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:39:54: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:39:54: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:39:54: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:39:54: Exiting…
Zigbee2MQTT:error 2021-09-26 16:39:54: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:39:55] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:40:04: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:40:04: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:40:04: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:40:04: Exiting…
Zigbee2MQTT:error 2021-09-26 16:40:04: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:40:05] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2021-09-26 16:40:13: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-26 16:40:13: Failed to start zigbee
Zigbee2MQTT:error 2021-09-26 16:40:13: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-09-26 16:40:13: Exiting…
Zigbee2MQTT:error 2021-09-26 16:40:13: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open /dev/ttyUSB0’
[16:40:14] INFO: Handing over control to Zigbee2mqtt Core …
你把usb网关插上去了没有?提示没有找到网关硬件
你的那个音箱是支持homekit得是吗?
已重启盒子 还是没显示
显示没有保存。
你试试这个?
用这个方法处理。
请问一下,在集成里面添加AppleTV,可以找到设备,可以输入pin,但是输入第一个pin之后,就提示出错了。
上面是输入Pin的提示,接着输入pin码,然后就出现下面的错误提示:
我查了日志里面没有相关提示信息。
是不是也可以手动安装?
配对码首位数是零吗
配对码首位不是0,是0都提交不了。我这个可以提交。对了,是升级到TVOS15之后就不行的。升级前可以用。
有可能是ha官方这个插件没有跟上15吧,等官方适配15 现在同行的系统是15了吗
