找到ip了吗??
按你们方法 恢复后。 再用默认。。之后 就什么都配对不上了。配对好多次后只能配对电子设备。不过信息不全。。零火供电的配不上(之前正常使用一个多月的),刚刚又试了一个,又可以配对一个了,我试试一晚上会不会掉线, 此外我想问Z2M配对是要连外网的,,,会不会与外网的服务器有关?配对服务器繁忙 所以下载不了数据 。。配对不了????
不需要外网的,你的网关也是我们店里的?
可以发个cli工具给我嘛,我想查下设备的ID,涂鸦局域网模式接入
你指 Z2M是本地配对的?完全不用到网上配对?
我之前 不知道你们店有网关买。我在其它地方买了。日后再买在你们店里配好 2652与盒子一起买,我的固件是Z2M官网上最新的。
最后我点击提示进入,加了一些语句到就可以正常配对了, 过了一天,还在正常使用,我上传图给你看看。
按照论坛里的添加摄像头方法添加后重启就进不去Homeassistant了 怎么办~~~
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-06-13 03:46:59 ERROR (MainThread) [root] Uncaught exception
File “/usr/local/lib/python3.9/runpy.py”, line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/local/lib/python3.9/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 203, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 191, in main
exit_code = runner.run(runtime_conf)
File “/usr/src/homeassistant/homeassistant/runner.py”, line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 642, in run_until_complete
return future.result()
File “/usr/src/homeassistant/homeassistant/runner.py”, line 101, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 127, in async_setup_hass
config_dict = await conf_util.async_hass_config_yaml(hass)
File “/usr/src/homeassistant/homeassistant/config.py”, line 354, in async_hass_config_yaml
await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
File “/usr/src/homeassistant/homeassistant/config.py”, line 713, in merge_packages_config
PACKAGES_CONFIG_SCHEMA(packages)
File “/usr/src/homeassistant/homeassistant/helpers/config_validation.py”, line 539, in verify
slug_validator(key)
File “/usr/src/homeassistant/homeassistant/helpers/config_validation.py”, line 520, in slug
raise vol.Invalid(f"invalid slug {value} (try {slg})")
voluptuous.error.Invalid: invalid slug Camera (try camera)
[finish] process exit code 1
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2022-06-13 03:51:25 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
slug_validator(key)
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[finish] process exit code 256
[finish] process received signal 15
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2022-06-13 03:52:48 ERROR (MainThread) [root] Uncaught exception
sys.exit(main())
slug_validator(key)
===Logs stream finished===
提示的信息是说添加摄像头的配置格式不对
没有完全按照教程做。
联系淘宝客服,拿还原镜像重新初始化。
是不是最新的固件对配置文件有新的要求?
已经还原了镜像 还是没用
上面已经回复你其他的解决办法,删除自定义组建里面的格力插件,你再往上翻看看吧
你是写了配置放在那里了?
全屏截图给我看看
这个截图是否你的配置
按照步骤删除HACS再安装,安装不上,显示 无法使用Github进行身份验证,请稍后再试。
授权过程未加速,请稍后或更换网络环境再试,也按照要求安装了FasterHosts
你这种网络环境,还原之后,就别删除hacs。直接用吧。如果下载不了,那么就用手动下载具体的插件。
hacs本身就是一个第三方的收集聚合插件,不是必须的,本身就有bug,加上国内的网络环境,如果实在上不了,你就用上面的手动下载插件方式下载插件,实在都下载不了,你把要下载的插件提交在这里,我们下载好了,你再下载回去
能够访问到github,也能够正常下载。就是安装hacs的时候报错。
把操作步骤逐步截图,这么说有点笼统
