麻烦老大把盒子容器的初始状态给发个截图,我自己对照一下,
快照哪里退回去吧
你把usb的设置做回来也不行?
你断电重启看看还能不能进入吧。我们也没有试过这种问题
最初usb那裏再沒有選項了, 後來回快照也卡著(上面有log)
你现在断电重启看能不能进入系统吧
我晚一点百度下,看看有没有解决方案
鎖了, 沒了選項啟動錯誤訊息: TASK ERROR: start failed: command ‘/usr/bin/kvm -id 101 -name homeassistant -chardev ‘socket,id=qmp,path=/var/run/qemu-server/101.qmp,server,nowait’ -mon ‘chardev=qmp,mode=control’ -chardev ‘socket,id=qmp-event,path=/var/run/qmeventd.sock,reconnect=5’ -mon ‘chardev=qmp-event,mode=control’ -pidfile /var/run/qemu-server/101.pid -daemonize -smbios ‘type=1,uuid=771a474a-94f2-49a4-b02f-0f6f093afedd’ -smp ‘4,sockets=1,cores=4,maxcpus=4’ -nodefaults -boot ‘menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg’ -vnc unix:/var/run/qemu-server/101.vnc,password -cpu kvm64,enforce,+kvm_pv_eoi,+kvm_pv_unhalt,+lahf_lm,+sep -m 4096 -device ‘pci-bridge,id=pci.1,chassis_nr=1,bus=pci.0,addr=0x1e’ -device ‘pci-bridge,id=pci.2,chassis_nr=2,bus=pci.0,addr=0x1f’ -device ‘vmgenid,guid=b63582d9-92f7-4a5d-a910-1e9062e77433’ -device ‘piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2’ -device ‘nec-usb-xhci,id=xhci,bus=pci.1,addr=0x1b’ -device ‘usb-tablet,id=tablet,bus=uhci.0,port=1’ -device ‘usb-host,bus=xhci.0,hostbus=1,hostport=3,id=usb0’ -device ‘VGA,id=vga,bus=pci.0,addr=0x2’ -device ‘virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3’ -iscsi ‘initiator-name=iqn.1993-08.org.debian:01:711aea26456f’ -drive ‘file=/var/lib/vz/template/iso/debian-10.6.0-amd64-DVD-1.iso,if=none,id=drive-ide2,media=cdrom,aio=threads’ -device ‘ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200’ -device ‘virtio-scsi-pci,id=scsihw0,bus=pci.0,addr=0x5’ -drive ‘file=/dev/pve/vm-101-disk-0,if=none,id=drive-scsi0,format=raw,cache=none,aio=native,detect-zeroes=on’ -device ‘scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100’ -netdev ‘type=tap,id=net0,ifname=tap101i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on’ -device ‘virtio-net-pci,mac=E6:48:60:68:E3:85,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300’ -machine ‘type=pc+pve0’’ failed: got timeout
百度了一圈,没有看到解决方案。我再看看谷歌看看
前面做了什么操作?
啥都没,就是插上了zigbee网关,开启了这个插件,再没动别的了
之前都可以?
插上去之前是不通电的状态插?还是直接插?
直插。期间也断电重启过
