N1安装homeassistant时错误。
[info] 切换系统网络源…
[warn] 备份系统源文件为 /etc/apt/sources.list.bak
[warn] 发现 armbian 源,替换清华源,如需要恢复请自行到 /etc/apt/sources.list.d/ 文件 夹中删除后缀名 “.bak”
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic InRelease
Get:2 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates InRelease [88.7 kB]
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-backports InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-security InRelease
Get:5 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic InRelease [18.3 kB]
Get:6 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates/universe arm64 Packages [1489 kB]
Get:7 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates/universe armhf Packages [1397 kB]
Get:8 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates/universe Transl ation-en [358 kB]
Get:9 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/main arm64 Packages [754 kB]
Get:10 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/main armhf Packages [631 kB ]
Get:11 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/bionic-utils armhf Packages [4465 B]
Get:12 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/bionic-utils arm64 Packages [4482 B]
Get:13 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/bionic-desktop arm64 Packag es [1949 B]
Get:14 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic/bionic-desktop armhf Packag es [2596 B]
Fetched 4749 kB in 4s (1144 kB/s)
Reading package lists… Done
Building dependency tree
2 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
N: Ignoring file ‘50unattended-upgrades.ucftmp’ in directory ‘/etc/apt/apt.conf.d/’ a s it has an invalid filename extension
[info] 安装 hassio 必要依赖…
Hit:2 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates InRelease
Hit:5 http://mirrors.tuna.tsinghua.edu.cn/armbian bionic InRelease
E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily un available)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
########################### Script Version: 2021.01.07.0###########################
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
Linux version 5.0.2-aml-s905 (root@vbox) (gcc version 7.3.1 20180425 [linaro-7.3-2018 .05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #5.7 7 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019
Linux aml 5.0.2-aml-s905 #5.77 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019 aarch64 aarch6 4 aarch64 GNU/Linux
安装curl socat jq avahi-daemon net-tools network-manager qrencode apparmor apparmor-u tils失败,请将检查上方安装错误信息。
[warn] 相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
设备是N1,系统是 ARMBIAN 5.77 user-built Ubuntu 18.04.5 LTS 5.0.2-aml-s905
请把错误信息完整的跟帖到上面的主题。
