You are running an unsupported installation. Learn more
Your installtion is running in an unhealthy state. Learn more
提示这个安装不了插件以及不能更新 Supervisor
日志提示这个
20-12-26 14:09:43 WARNING (SyncWorker_0) [supervisor.docker.interface] Can’t find homeassistant/aarch64-hassio-supervisor for cleanup
20-12-26 14:09:43 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-26 14:09:43 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker storage driver btrfs is not supported!
20-12-26 14:09:43 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker logging driver json-file is not supported!
20-12-26 14:09:43 WARNING (MainThread) [supervisor.resolution.evaluations.base] The configuration of Docker is not supported (more-info: https://www.home-assistant.io/more-info/unsupported/docker_configuration)
