机器是树莓派4,刷入了官方的 hassos_rpi4-4.16.img.gz安装包
网线连接的树莓派,打开http://homeassistant.local:8123/后台提示大概20分钟完成 但是一直报错
报错如下
Can’t install homeassistant/raspberrypi4-homeassistant:0.118.5 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi4-homeassistant:0.118.5: No such image: homeassistant/raspberrypi4-homeassistant:0.118.5”).
This error is often caused by not having enough disk space available. Available space in /data is: 25.7 GiB
Error on Home Assistant installation. Retry in 30sec
Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:0.118.5
Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 0.118.5.
