安装不成功。不知道怎么回事
[info]: 发现系统已安装 docker,跳过 docker 安装
[info]: 切换 Docker 源为国内源…
[info]: 切换国内源完成
[info]: 安装 hassio…
下载 hassio_install.sh 官方脚本 第1次
从 hub.docker.com 下载 homeassistant/qemuarm-64-homeassistant:0.118.4…
0.118.4: Pulling from homeassistant/qemuarm-64-homeassistant
Digest: sha256:21472819726951a45a530d05d028fe7a97ad48e1af0de593989408e3961802e7
Status: Image is up to date for homeassistant/qemuarm-64-homeassistant:0.118.4
docker.io/homeassistant/qemuarm-64-homeassistant:0.118.4
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds…
[warn]
[warn] Docker is using json-file and not ‘journald’ as the logging driver, this is not supported.
[info] Creating NetworkManager configuration
[warn] Changes are needed to the /etc/network/interfaces file
[info] If you have modified the network on the host manualy, those can now be overwritten
[info] If you do not overwrite this now you need to manually adjust it later
[info] Do you want to proceed with that? [N/y]
Y
[info] Replacing /etc/network/interfaces
[info] Restarting NetworkManager
[info] Install supervisor Docker container
Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: no such host
Unit hassio-supervisor.service could not be found.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
Linux version 5.0.2-aml-s905 (root@vbox) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #5.77 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019
Linux aml 5.0.2-aml-s905 #5.77 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出…
