- 一、实现前置条件:
- 一台能上网的电脑;
- 已有自建(云、docker等均可)的Node-Red服务,及Granafa服务。(部署具体方法自行百度)
- Granafa需安装Echart插件,插件地址:https://github.com/xiejia1992/echartsmap-panel (直接git clone 到/var/lib/grafana/plugins/ 目录下,就能使用。支持prometheus和httpget获取数据,或者编辑假数据。)
- 二、效果预览:
- 三、实现步骤:
NodeRed配置;
[ { "id": "655733c1.822acc", "type": "change", "z": "2aa70934.8a16b6", "name": "", "rules": [ { "t": "set", "p": "payload.data.result[0].value[1]", "pt": "msg", "to": "50", "tot": "num" }, { "t": "set", "p": "headers", "pt": "msg", "to": "{}", "tot": "json" }, { "t": "set", "p": "headers.content.type", "pt": "msg", "to": "application/json", "tot": "str" } ], "action": "", "property": "", "from": "", "to": "", "reg": false, "x": 160, "y": 240, "wires": [ [ "bd25bf97.249c" ] ] } ] -
Granafa配置;
{ "annotations": { "list": [ { "builtIn": 1, "datasource": "-- Grafana --", "enable": true, "hide": true, "iconColor": "rgba(0, 211, 255, 1)", "name": "Annotations & Alerts", "type": "dashboard" } ] }, "editable": true, "gnetId": null, "graphTooltip": 0, "id": 27, "links": [], "panels": [ { "EchartsOption": "option = {\n tooltip : { \n trigger: 'item' \n }, \n \n visualMap: {\n show: true,\n min: 0,\n max: 200,\n left: 'left',\n top: 'bottom',\n calculable: true,\n seriesIndex: [1],\n inRange: {\n color: ['#A5CC82', '#00467F']\n },\n textStyle: {\n color: '#fff'\n }\n\n },\n\n geo: {\n show: true,\n map: 'china',\n zoom: 1.2,\n label: {\n normal: {\n show: false\n },\n emphasis: {\n show: false\n }\n },\n roam: true,\n itemStyle: {\n normal: {\n areaColor: '#fff',\n borderColor: '#3B5077' \n },\n emphasis: {\n areaColor: 'lightgreen'\n }\n }\n },\n\n series: [{\n type: 'scatter',\n coordinateSystem: 'geo',\n symbolSize: function(val) {\n return 0.1;\n },\n itemStyle: {\n normal: {\n color: '#05C3F9'\n }\n }\n },\n {\n name: '数据',\n type: 'map',\n map: 'china',\n geoIndex: 0,\n aspectScale: 0.75, \n showLegendSymbol: false, \n label: {\n normal: {\n show: false\n },\n emphasis: {\n show: false,\n textStyle: {\n color: 'red'\n }\n }\n },\n roam: true,\n itemStyle: {\n normal: {\n areaColor: '#fff',\n borderColor: '#3B5077',\n },\n emphasis: {\n areaColor: '#2B91B7'\n }\n },\n animation: false,\n data: data\n }\n ]\n };", "IS_MAP": true, "USE_FAKE_DATA": false, "USE_URL": true, "datasource": null, "fakeData": "", "fieldConfig": { "defaults": { "custom": {} }, "overrides": [] }, "gridPos": { "h": 11, "w": 8, "x": 0, "y": 0 }, "id": 2, "map": "中国", "pluginVersion": "7.1.1", "request": "GET", "targets": [ { "format": "time_series", "group": [], "metricColumn": "none", "rawQuery": false, "rawSql": "SELECT\n Date AS \"time\",\n id\nFROM RFID\nWHERE\n $__timeFilter(Date)\nORDER BY Date", "refId": "A", "select": [ [ { "params": [ "id" ], "type": "column" } ] ], "table": "RFID", "timeColumn": "Date", "timeColumnType": "timestamp", "where": [ { "name": "$__timeFilter", "params": [], "type": "macro" } ] } ], "timeFrom": null, "timeShift": null, "title": "Map-prometheus", "type": "echartsmap-panel", "updateInterval": 5000, "url": " " }, { "EchartsOption": "var mapName = 'china'\nvar data = [{\n name: \"北京\",\n value: 3\n },\n {\n name: \"天津\",\n value: 0\n },\n {\n name: \"河北\",\n value: 0\n },\n {\n name: \"山西\",\n value: 0\n },\n {\n name: \"内蒙古\",\n value: 0\n },\n {\n name: \"辽宁\",\n value: 1\n },\n {\n name: \"吉林\",\n value: 0\n },\n {\n name: \"黑龙江\",\n value: 0\n },\n {\n name: \"上海\",\n value: 0\n },\n {\n name: \"江苏\",\n value: 0\n },\n {\n name: \"浙江\",\n value: 2\n },\n {\n name: \"安徽\",\n value: 0\n },\n {\n name: \"福建\",\n value: 4\n },\n {\n name: \"江西\",\n value: 0\n },\n {\n name: \"山东\",\n value: 0\n },\n {\n name: \"河南\",\n value: 0\n },\n {\n name: \"湖北\",\n value: 1\n },\n {\n name: \"湖南\",\n value: 0\n },\n {\n name: \"重庆\",\n value: 0\n },\n {\n name: \"四川\",\n value: 0\n },\n {\n name: \"贵州\",\n value: 0\n },\n {\n name: \"云南\",\n value: 0\n },\n {\n name: \"西藏\",\n value: 0\n },\n {\n name: \"陕西\",\n value: 0\n },\n {\n name: \"甘肃\",\n value: 0\n },\n {\n name: \"青海\",\n value: 0\n },\n {\n name: \"宁夏\",\n value: 0\n },\n {\n name: \"新疆\",\n value: 0\n },\n {\n name: \"广东\",\n value: 0\n },\n {\n name: \"广西\",\n value: 0\n },\n {\n name: \"海南\",\n value: 0\n },\n];\n \nvar geoCoordMap = {};\n\n/*获取地图数据*/\nmyChart.showLoading();\nvar mapFeatures = echarts.getMap(mapName).geoJson.features;\nmyChart.hideLoading();\nmapFeatures.forEach(function(v) {\n // 地区名称\n var name = v.properties.name;\n // 地区经纬度\n geoCoordMap[name] = v.properties.cp;\n\n});\n\nvar max = 480,\n min = 9; // todo \nvar maxSize4Pin = 100,\n minSize4Pin = 20;\n\nvar convertData = function(data) {\n var res = [];\n for (var i = 0; i < data.length; i++) {\n var geoCoord = geoCoordMap[data[i].name];\n if (geoCoord) {\n res.push({\n name: data[i].name,\n value: geoCoord.concat(data[i].value),\n });\n }\n }\n return res;\n};\noption = {\n tooltip: {\n padding: 4,\n enterable: true,\n transitionDuration: 1,\n textStyle: {\n color: '#000',\n decoration: 'none',\n },\n extraCssText:'box-shadow:2px 2px 8px rgba(204,204,204,0.8)',\n backgroundColor:'#fff',\n borderRadius: 6,\n textStyle:{\n color:'black',\n },\n padding:[5,10],\n formatter: function(params) {\n return params.name+':'+params.value[2]+'单'\n }\n\n },\n \n geo: {\n show: true,\n map: mapName,\n label: {\n normal: {\n show: false\n },\n emphasis: {\n show: false,\n }\n },\n roam: false,\n itemStyle: {\n normal: {\n borderWidth: 1,\n areaColor: '#e3e3e3',\n borderColor: '#e3e3e3',\n },\n emphasis: {\n areaColor: '#e3e3e3',\n borderColor: '#e3e3e3',\n }\n }\n },\n series: [{\n name: '散点',\n type: 'effectScatter',\n coordinateSystem: 'geo',\n data:convertData(data),\n rippleEffect: {\n period: 3.5, //波纹秒数\n brushType: 'stroke', //stroke(涟漪)和fill(扩散),两种效果\n scale: 8//波纹范围\n },\n symbolSize: function(val) {\n if(val[2] == 1 || val[2] == 2){\n return 4\n }else if(val[2] == 3){\n return 4.5\n }else if(val[2] == 4) {\n return 5\n }else if(val[2] == 5) {\n return 5.5\n }else if(val[2] == 6) {\n return 6\n }else if(val[2] == 7) {\n return 6.5\n }else if(val[2] > 7) {\n return 7\n }\n // return 7\n },\n label: {\n normal: {\n show: false\n },\n emphasis: {\n show: false\n }\n },\n itemStyle: {\n normal: {\n color: function (e) {\n if(e.value[2] == 0){\n return 'transparent'\n }else if(e.value[2] == 1){\n return '#76A3FF'\n }else if(e.value[2] == 2){\n return '#7CDE9A'\n }else if(e.value[2] == 3){\n return '#FF7F33'\n }else {\n return '#F53B3B'\n }\n },\n }\n }\n },\n ]\n};", "IS_MAP": false, "USE_FAKE_DATA": false, "USE_URL": true, "datasource": null, "fakeData": "", "fieldConfig": { "defaults": { "custom": {} }, "overrides": [] }, "gridPos": { "h": 11, "w": 13, "x": 9, "y": 0 }, "id": 4, "map": "china", "pluginVersion": "7.1.1", "request": "", "targets": [ { "format": "time_series", "group": [], "metricColumn": "none", "rawQuery": false, "rawSql": "SELECT\n Date AS \"time\",\n id\nFROM RFID\nWHERE\n $__timeFilter(Date)\nORDER BY Date", "refId": "A", "select": [ [ { "params": [ "id" ], "type": "column" } ] ], "table": "RFID", "timeColumn": "Date", "timeColumnType": "timestamp", "where": [ { "name": "$__timeFilter", "params": [], "type": "macro" } ] } ], "timeFrom": null, "timeShift": null, "title": "Panel Title", "type": "echartsmap-panel", "updateInterval": 60000, "url": "" } ], "schemaVersion": 26, "style": "dark", "tags": [], "templating": { "list": [] }, "time": { "from": "now-6h", "to": "now" }, "timepicker": { "refresh_intervals": [ "10s", "30s", "1m", "5m", "15m", "30m", "1h", "2h", "1d" ] }, "timezone": "", "title": "REDMAP", "uid": "gQ_pERpGk", "version": 6 }
其它炫酷图形可在ECharts Galler开源学习网找到后使用此方法接入数据源。
