npm ERR! /root/.npm/_logs/2020-10-27T14_44_34_168Z-debug.log
2020-10-27T22:44:35: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-10-27T22:44:35: PM2 log: App [npm:0] starting in -fork mode-
2020-10-27T22:44:35: PM2 log: App [npm:0] online
zigbee2mqtt@1.15.0 start /zigbee2mqtt-1.15.0
node index.js
Zigbee2MQTT:info 2020-10-27 22:44:41: Logging to console and directory: ‘/share/zigbee2mqtt/log/2020-10-27.22-44-41’ filename: log.txt
Zigbee2MQTT:info 2020-10-27 22:44:43: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info 2020-10-27 22:44:43: Starting zigbee-herdsman…
Zigbee2MQTT:error 2020-10-27 22:44:43: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-27 22:44:43: Failed to start zigbee
Zigbee2MQTT:error 2020-10-27 22:44:43: Exiting…
Zigbee2MQTT:error 2020-10-27 22:44:43: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open ’tcp://192.168.2.133:1024’’
at Znp. (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
at Generator.next ()
at /zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
at new Promise ()
at __awaiter (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
at SerialPort. (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
at SerialPort._error (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
npm
ERR! code ELIFECYCLE
npm ERR! errno 1
npm
ERR! zigbee2mqtt@1.15.0 start:node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.15.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!
/root/.npm/_logs/2020-10-27T14_44_44_002Z-debug.log
2020-10-27T22:44:45: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-10-27T22:44:45: PM2 log: App [npm:0] starting in -fork mode-
2020-10-27T22:44:45: PM2 log: App [npm:0] online
node index.js
Zigbee2MQTT:info 2020-10-27 22:44:51: Logging to console and directory: ‘/share/zigbee2mqtt/log/2020-10-27.22-44-51’ filename: log.txt
Zigbee2MQTT:info 2020-10-27 22:44:53: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info 2020-10-27 22:44:53: Starting zigbee-herdsman…
Zigbee2MQTT:error 2020-10-27 22:44:53: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-27 22:44:53: Failed to start zigbee
Zigbee2MQTT:error 2020-10-27 22:44:53: Exiting…
Zigbee2MQTT:error 2020-10-27 22:44:53: Error: Error while opening serialport ‘Error: Error: No such file or directory, cannot open ’tcp://192.168.2.133:1024’’
at new Promise ()
npm
