机器N1 用论坛一键脚本安装了hassio
从咸鱼上买了个z2m配置这个插件,怎么弄都不行,不晓得哪里的问题
2020-10-18T15:15:36: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-10-18T15:15:36: PM2 log: App [npm:0] starting in -fork mode-
2020-10-18T15:15:36: PM2 log: App [npm:0] online
zigbee2mqtt@1.15.0 start /zigbee2mqtt-1.15.0
node index.js
Zigbee2MQTT:info 2020-10-18 15:15:41: Logging to console and directory: ‘/share/zigbee2mqtt/log/2020-10-18.15-15-41’ filename: log.txt
Zigbee2MQTT:info 2020-10-18 15:15:43: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info 2020-10-18 15:15:43: Starting zigbee-herdsman…
Zigbee2MQTT:error 2020-10-18 15:16:03: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-18 15:16:03: Failed to start zigbee
Zigbee2MQTT:error 2020-10-18 15:16:03: Exiting…
Zigbee2MQTT:error 2020-10-18 15:16:03: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter. (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:92:31)
at Generator.throw ()
at rejected (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm
ERR! code ELIFECYCLE
npm ERR! errno 1
npm
ERR! zigbee2mqtt@1.15.0 start:node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.15.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2020-10-18T07_16_03_472Z-debug.log
配置文件
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: ‘mqtt://192.168.1.189’
user: mqtt
password: mqtt
serial:
port: ‘tcp://192.168.1.175:8880’
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
socat:
enabled: false
master: ‘pty,raw,echo=0,link=/dev/ttyZ2M,mode=777’
slave: ‘tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5’
restartdelay: 1
initialdelay: 1
options: ‘-d -d’
log: false
