如图所示风扇的空洞是非常大,想装什么就装什么!!!!
风扇用了有一年多了,买回来的时候就想改装了
,太太怀孕了
,所以~~~
加一个光感,可以在lx为0的状态下关闭风扇。
本来想使用esp8266但共需要用10个GPIO,只能使用esp32。
接线原理:
1、强电区------风扇电机是4线,分别是红(高速),白(中速),蓝(低速),和黑(零线); 摇头是独立的低 速电机。以上使用一个4路继电器控制。
2、弱电区------原来的1档2档3档和摇头档位,分别连接GPIO用binary_sensor来接入,目得是纯物理的情况下也可以控制风扇。
固件使用esphome 代码如下:
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: “"
password: ""
fast_connect: on
ap:
ssid: “Esp32 01 Fan”
password: ""
manual_ip:
static_ip: 192.168.100.9
gateway: 192.168.100.1
subnet: 255.255.255.0
captive_portal:
logger:
api:
password: "*****”
ota:
password: “******”
i2c:
sda: 21
scl: 22
scan: True
sensor:
- platform: bh1750
i2c_id: bh_a
address: 0x23
update_interval: 60s
switch:
platform: restart
platform: gpio
pin: 16
inverted: yes
platform: gpio
pin: 17
inverted: yes
interlock: [mid, fast] -
platform: gpio
pin: 18
inverted: yes
interlock: [low, fast] -
platform: gpio
pin: 19
inverted: yes
interlock: [low, mid]
binary_sensor:
platform: status
#连接状态
platform: gpio
pin: {number: GPIO14, mode: INPUT_PULLUP, inverted: True}
filters: [{delayed_on: 40ms}, {delayed_off: 40ms}]
on_state: [{switch.toggle: yt}] -
platform: gpio
pin: {number: GPIO25, mode: INPUT_PULLUP, inverted: True}
on_state: [{switch.toggle: low}] -
platform: gpio
pin: {number: GPIO26, mode: INPUT_PULLUP, inverted: True}
on_state: [{switch.toggle: mid}] -
platform: gpio
pin: {number: GPIO27, mode: INPUT_PULLUP, inverted: True}
on_state: [{switch.toggle: fast}]
-------目前还需在写二个自动化是当风扇1档2档3档都关闭,摇头自动关闭;在19-01时光感为0,关闭风扇。
他那个貌似有互锁的
