[{"id":"bf8c7400.ea37d8","type":"subflow","name":"电脑控制","info":"","category":"","in":[{"x":60,"y":200,"wires":[{"id":"9eaa29e2.7d6148"}]}],"out":[{"x":800,"y":200,"wires":[{"id":"65ec798b.232838","port":0},{"id":"1a425be8.7fbf44","port":0},{"id":"c8e1336e.d57c7","port":0},{"id":"453c332f.f9294c","port":0},{"id":"72334e01.69b4","port":0},{"id":"37bd5968.748846","port":0},{"id":"dc282531.eaf2a8","port":0},{"id":"9f4cffe4.50ee3","port":0}]}],"env":[]},{"id":"65ec798b.232838","type":"exec","z":"bf8c7400.ea37d8","command":"curl -X GET http://192.168.123.3:8000/?action=System.Shutdown","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"电脑关机","x":520,"y":80,"wires":[[],[],[]]},{"id":"1a425be8.7fbf44","type":"exec","z":"bf8c7400.ea37d8","command":"curl -X GET http://192.168.123.3:8000/?action=System.Restart","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"电脑重启","x":521,"y":160,"wires":[[],[],[]]},{"id":"c8e1336e.d57c7","type":"exec","z":"bf8c7400.ea37d8","command":"curl -X GET http://192.168.123.3:8000/?action=System.Sleep","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"电脑睡眠","x":521,"y":240,"wires":[[],[],[]]},{"id":"453c332f.f9294c","type":"exec","z":"bf8c7400.ea37d8","command":"curl -X GET http://192.168.123.3:8000/?action=System.Dormancy","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"电脑休眠","x":521,"y":320,"wires":[[],[],[]]},{"id":"9eaa29e2.7d6148","type":"switch","z":"bf8c7400.ea37d8","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"0/On","vt":"str"},{"t":"eq","v":"1/On","vt":"str"},{"t":"eq","v":"2/On","vt":"str"},{"t":"eq","v":"3/On","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":190,"y":200,"wires":[["65ec798b.232838","6070b854.bc1218"],["1a425be8.7fbf44","e41b81ec.cce18"],["c8e1336e.d57c7","7376d342.2d4d4c"],["453c332f.f9294c","b29cf03b.d206b"]]},{"id":"72334e01.69b4","type":"change","z":"bf8c7400.ea37d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":380,"wires":[[]]},{"id":"6070b854.bc1218","type":"delay","z":"bf8c7400.ea37d8","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":490,"y":380,"wires":[["72334e01.69b4"]]},{"id":"e41b81ec.cce18","type":"delay","z":"bf8c7400.ea37d8","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":490,"y":420,"wires":[["37bd5968.748846"]]},{"id":"37bd5968.748846","type":"change","z":"bf8c7400.ea37d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":420,"wires":[[]]},{"id":"7376d342.2d4d4c","type":"delay","z":"bf8c7400.ea37d8","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":490,"y":460,"wires":[["dc282531.eaf2a8"]]},{"id":"dc282531.eaf2a8","type":"change","z":"bf8c7400.ea37d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":460,"wires":[[]]},{"id":"b29cf03b.d206b","type":"delay","z":"bf8c7400.ea37d8","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":490,"y":500,"wires":[["9f4cffe4.50ee3"]]},{"id":"9f4cffe4.50ee3","type":"change","z":"bf8c7400.ea37d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":500,"wires":[[]]},{"id":"f1f0414d.0798f","type":"redmatic-homekit-universal","z":"bc05d6c9.ac4638","bridgeConfig":"2816d8d3.7b3a88","name":"电脑","services":[{"subtype":"0","service":"Outlet","name":"关闭电脑"},{"subtype":"1","service":"Outlet","name":"重启电脑"},{"subtype":"2","service":"Outlet","name":"电脑睡眠"},{"subtype":"3","service":"Outlet","name":"电脑休眠"}],"x":90,"y":760,"wires":[["ee4957d8.322328"]]},{"id":"ee4957d8.322328","type":"subflow:bf8c7400.ea37d8","z":"bc05d6c9.ac4638","name":"电脑控制","env":[],"x":220,"y":760,"wires":[["f1f0414d.0798f"]]},{"id":"2816d8d3.7b3a88","type":"redmatic-homekit-bridge","z":"","name":"电脑控制","username":"CC:22:3D:29:A6:EF","pincode":"556-35-274","port":"51847"}]
哎 这是homekit的
