| ham.1 | 2020-02-23 11:00:38.764 | info | (2109) stateChange ham.1.空调.空调.Rotation-Speed {“val”:0,“ack”:true,“ts”:1582426838751,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530928} |
| ham.1 | 2020-02-23 11:00:38.763 | info | (2109) stateChange ham.1.空调.空调.Temperature-Display-Units {“val”:0,“ack”:true,“ts”:1582426838750,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530922} |
| ham.1 | 2020-02-23 11:00:38.762 | info | (2109) stateChange ham.1.空调.空调.Heating-Threshold-Temperature {“val”:0,“ack”:true,“ts”:1582426838750,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582426838750} |
| ham.1 | 2020-02-23 11:00:38.748 | info | (2109) stateChange ham.1.空调.空调.Cooling-Threshold-Temperature {“val”:10,“ack”:true,“ts”:1582426838685,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582395744958} |
| ham.1 | 2020-02-23 11:00:38.747 | info | (2109) stateChange ham.1.空调.空调.Swing-Mode {“val”:0,“ack”:true,“ts”:1582426838685,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530922} |
| ham.1 | 2020-02-23 11:00:38.745 | info | (2109) stateChange ham.1.空调.空调.Name {“val”:"",“ack”:true,“ts”:1582426838675,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582396655590} |
| ham.1 | 2020-02-23 11:00:38.743 | info | (2109) stateChange ham.1.空调.空调.Lock-Physical-Controls {“val”:0,“ack”:true,“ts”:1582426838674,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530921} |
| ham.1 | 2020-02-23 11:00:38.742 | info | (2109) stateChange ham.1.空调.空调.Rotation-Speed {“val”:0,“ack”:true,“ts”:1582426838674,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530928} |
| ham.1 | 2020-02-23 11:00:38.741 | info | (2109) stateChange ham.1.空调.空调.Swing-Mode {“val”:0,“ack”:true,“ts”:1582426838674,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530922} |
| ham.1 | 2020-02-23 11:00:38.740 | info | (2109) stateChange ham.1.空调.空调.Heating-Threshold-Temperature {“val”:23,“ack”:true,“ts”:1582426838674,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582426838674} |
| ham.1 | 2020-02-23 11:00:38.739 | info | (2109) stateChange ham.1.空调.空调.Cooling-Threshold-Temperature {“val”:23,“ack”:true,“ts”:1582426838674,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582426838674} |
| ham.1 | 2020-02-23 11:00:38.737 | info | (2109) stateChange ham.1.空调.空调.Current-Temperature {“val”:23,“ack”:true,“ts”:1582426838673,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530920} |
| ham.1 | 2020-02-23 11:00:38.736 | info | (2109) stateChange ham.1.空调.空调.Target-Heater-Cooler-State {“val”:0,“ack”:true,“ts”:1582426838673,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530920} |
| ham.1 | 2020-02-23 11:00:38.735 | info | (2109) stateChange ham.1.空调.空调.Current-Heater-Cooler-State {“val”:0,“ack”:true,“ts”:1582426838673,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530920} |
| ham.1 | 2020-02-23 11:00:38.734 | info | (2109) stateChange ham.1.空调.空调.Active {“val”:0,“ack”:true,“ts”:1582426838673,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530920} |
| ham.1 | 2020-02-23 11:00:38.713 | info | (2109) stateChange ham.1.空调.空调.Name {“val”:“空调”,“ack”:true,“ts”:1582426838673,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582426838673} |
| ham.1 | 2020-02-23 11:00:38.713 | info | (2109) stateChange ham.1.空调.Accessory-Information.Accessory-Flags {“val”:0,“ack”:true,“ts”:1582426838672,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530919} |
| ham.1 | 2020-02-23 11:00:38.712 | info | (2109) stateChange ham.1.空调.Accessory-Information.Hardware-Revision {“val”:"",“ack”:true,“ts”:1582426838672,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530919} |
| ham.1 | 2020-02-23 11:00:38.711 | info | (2109) stateChange ham.1.空调.Accessory-Information.Firmware-Revision {“val”:“1.0”,“ack”:true,“ts”:1582426838671,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530919} |
| ham.1 | 2020-02-23 11:00:38.711 | info | (2109) stateChange ham.1.空调.Accessory-Information.Serial-Number {“val”:“Undefined”,“ack”:true,“ts”:1582426838671,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530919} |
| ham.1 | 2020-02-23 11:00:38.710 | info | (2109) stateChange ham.1.空调.Accessory-Information.Name {“val”:“空调”,“ack”:true,“ts”:1582426838671,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530918} |
| ham.1 | 2020-02-23 11:00:38.709 | info | (2109) stateChange ham.1.空调.Accessory-Information.Model {“val”:“AC Partner(HeaterCooler)”,“ack”:true,“ts”:1582426838671,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:158239253091 |
| ham.1 | 2020-02-23 11:00:38.708 | info | (2109) stateChange ham.1.空调.Accessory-Information.Manufacturer {“val”:“XiaoMi”,“ack”:true,“ts”:1582426838670,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530917} |
| ham.1 | 2020-02-23 11:00:38.707 | info | (2109) stateChange ham.1.空调.Accessory-Information.Identify {“val”:false,“ack”:true,“ts”:1582426838612,“q”:0,“from”:“system.adapter.ham.1”,“user”:“system.user.admin”,“lc”:1582392530917} |
| ham.1 | 2020-02-23 11:00:38.408 | info | (2109) updateState 空调.空调.Rotation-Speed: value = 0 /common= {“type”:“number”,“unit”:"%",“min”:0,“max”:100,“read”:true,“write”:true,“role”:“level”,“name”:“Rotation Speed”} |
| ham.1 | 2020-02-23 11:00:38.406 | info | (2109) updateState 空调.空调.Temperature-Display-Units: value = 0 /common= {“type”:“number”,“min”:0,“max”:1,“read”:true,“write”:true,“role”:“level”,“name”:“Temperature Display Units”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.405 | info | (2109) updateState 空调.空调.Heating-Threshold-Temperature: value = 0 /common= {“type”:“number”,“unit”:“°C”,“min”:0,“max”:25,“read”:true,“write”:true,“role”:“level.temperature”,“name”:"Heating Threshold T |
| ham.1 | 2020-02-23 11:00:38.403 | info | (2109) updateState 空调.空调.Cooling-Threshold-Temperature: value = 10 /common= {“type”:“number”,“unit”:“°C”,“min”:10,“max”:35,“read”:true,“write”:true,“role”:“level.temperature”,“name”:"Cooling Threshold |
| ham.1 | 2020-02-23 11:00:38.402 | info | (2109) updateState 空调.空调.Swing-Mode: value = 0 /common= {“type”:“number”,“min”:0,“max”:1,“read”:true,“write”:true,“role”:“level”,“name”:“Swing Mode”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.400 | info | (2109) updateState 空调.空调.Name: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.399 | info | (2109) updateState 空调.空调.Lock-Physical-Controls: value = 0 /common= {“type”:“number”,“min”:0,“max”:1,“read”:true,“write”:true,“role”:“level”,“name”:“Lock Physical Controls”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.397 | info | (2109) updateState 空调.空调.Rotation-Speed: value = 0 /common= {“type”:“number”,“unit”:"%",“min”:0,“max”:3,“read”:true,“write”:true,“role”:“level”,“name”:“Rotation Speed”} |
| ham.1 | 2020-02-23 11:00:38.396 | info | (2109) updateState 空调.空调.Swing-Mode: value = 0 /common= {“type”:“number”,“min”:0,“max”:1,“read”:true,“write”:true,“role”:“level”,“name”:“Swing Mode”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.394 | info | (2109) updateState 空调.空调.Heating-Threshold-Temperature: value = 23 /common= {“type”:“number”,“unit”:“°C”,“min”:17,“max”:30,“read”:true,“write”:true,“role”:“level.temperature”,“name”:"Heating Threshold |
| ham.1 | 2020-02-23 11:00:38.392 | info | (2109) updateState 空调.空调.Cooling-Threshold-Temperature: value = 23 /common= {“type”:“number”,“unit”:“°C”,“min”:17,“max”:30,“read”:true,“write”:true,“role”:“level.temperature”,“name”:"Cooling Threshold |
| ham.1 | 2020-02-23 11:00:38.391 | info | (2109) updateState 空调.空调.Current-Temperature: value = 23 /common= {“type”:“number”,“unit”:“°C”,“min”:-20,“max”:60,“read”:true,“write”:false,“role”:“value.temperature”,“name”:“Current Temperature”} |
| ham.1 | 2020-02-23 11:00:38.389 | info | (2109) updateState 空调.空调.Target-Heater-Cooler-State: value = 0 /common= {“type”:“number”,“min”:0,“max”:2,“read”:true,“write”:true,“role”:“level”,“name”:“Target Heater Cooler State”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.388 | info | (2109) updateState 空调.空调.Current-Heater-Cooler-State: value = 0 /common= {“type”:“number”,“min”:0,“max”:3,“read”:true,“write”:false,“role”:“value”,“name”:“Current Heater Cooler State”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.386 | info | (2109) updateState 空调.空调.Active: value = 0 /common= {“type”:“number”,“min”:0,“max”:1,“read”:true,“write”:true,“role”:“level”,“name”:“Active”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.384 | info | (2109) updateState 空调.空调.Name: value = 空调 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.383 | info | (2109) updateChannel 空调.空调: name = 空调 |
| ham.1 | 2020-02-23 11:00:38.381 | info | (2109) updateState 空调.Accessory-Information.Accessory-Flags: value = 0 /common= {“type”:“number”,“min”:0,“max”:4294967295,“read”:true,“write”:false,“role”:“value”,“name”:“Accessory Flags”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.379 | info | (2109) updateState 空调.Accessory-Information.Hardware-Revision: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Hardware Revision”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.378 | info | (2109) updateState 空调.Accessory-Information.Firmware-Revision: value = 1.0 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Firmware Revision”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.377 | info | (2109) updateState 空调.Accessory-Information.Serial-Number: value = Undefined /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Serial Number”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.376 | info | (2109) updateState 空调.Accessory-Information.Name: value = 空调 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.374 | info | (2109) updateState 空调.Accessory-Information.Model: value = AC Partner(HeaterCooler) /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Model”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.373 | info | (2109) updateState 空调.Accessory-Information.Manufacturer: value = XiaoMi /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Manufacturer”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.371 | info | (2109) updateState 空调.Accessory-Information.Identify: value = false /common= {“type”:“boolean”,“read”:false,“write”:true,“role”:“button”,“name”:“Identify”,“unit”:""} |
| ham.1 | 2020-02-23 11:00:38.367 | info | (2109) updateChannel 空调.Accessory-Information: name = undefined |
| ham.1 | 2020-02-23 11:00:38.364 | info | (2109) updateDev 空调: name = 空调 /type= 1 |
| ham.1 | 2020-02-23 11:00:36.335 | info | (2109) All Libraries installed/updated |
| ham.1 | 2020-02-23 11:00:36.333 | info | (2109) Install/Update homebridge-mi-acpartner |
| ham.1 | 2020-02-23 11:00:36.332 | info | (2109) Install/Update the following Libraries: homebridge-mi-acpartner |
| ham.1 | 2020-02-23 11:00:36.328 | info | (2109) Need to install/update homebridge@0.4.50 |
| ham.1 | 2020-02-23 11:00:36.285 | info | (2109) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v10.18.1 |
| host.smarthomefans-iobroker1 | 2020-02-23 11:00:32.498 | info | instance system.adapter.ham.1 terminated with code 156 (156) |
| host.smarthomefans-iobroker1 | 2020-02-23 11:00:32.497 | error | Caught by controller[1]: [2020-2-23 11:00:28 AM] [XiaoMiAcPartner] [ERROR]Device 192.168.2.103 -> Error: Call to device timed out |
| ham.1 | 2020-02-23 11:00:31.973 | info | (2052) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason |
| ham.1 | 2020-02-23 11:00:31.971 | info | (2052) terminating |
| ham.1 | 2020-02-23 11:00:31.963 | info | (2052) cleaned everything up… |
| ham.1 | 2020-02-23 11:00:31.961 | info | (2052) Got terminate signal TERMINATE_YOURSELF |
| host.smarthomefans-iobroker1 | 2020-02-23 11:00:31.954 | info | stopInstance system.adapter.ham.1 send kill signal |
| host.smarthomefans-iobroker1 | 2020-02-23 11:00:31.949 | info | stopInstance system.adapter.ham.1 (force=false, process=true) |
79这个不能用。只有旧的那两款一百多的可以
好的,谢谢!那么买错了哦,
我也是同一个问题,试过两个插件,都没有报错,但是家庭里按了会未响应。不知道后期会不会兼容
我用的也是79的。米家空调伴侣2。一样的问题。不知道后期是否会支持。。
我们都没有买这个79的,没有大神研究所以支持遥遥无期。因为阉割了功率,判断不了状态。可以咨询一下盐巴,移动那个垃圾是支持直接接入的。我用着感觉还不错。不过要看清楚自己的空调类型,看看是否完美支持。
大佬移动的是用x11还是X12~~这2个什么区别啊~
x11貌似是插座,x12是空调伴侣
估算的
怪不得一直觉得很奇怪 只要空调启动了 就一直是一个数字
正常外机停机了功率会很低才对
小米空调伴侣2 ,同样失败,请问现在解决了吗
请问现在解决了吗
你的局域网有问题,你拿回家换了就好了啊
