报错,日志是这样,怎么处理呀?
Logger: homeassistant.setup
Source: setup.py:347
First occurred: 2023年5月1日 20:00:15 (6 occurrences)
Last logged: 2023年5月1日 20:00:15
Unable to prepare setup for platform xiaomi_miot.fan: Platform not found (cannot import name ‘SPEED_OFF’ from ‘homeassistant.components.fan’ (/usr/src/homeassistant/homeassistant/components/fan/init.py)).
Unable to prepare setup for platform xiaomi_miot.climate: Platform not found (cannot import name ‘SPEED_OFF’ from ‘homeassistant.components.fan’ (/usr/src/homeassistant/homeassistant/components/fan/init.py)).
Unable to prepare setup for platform xiaomi_miot.cover: Platform not found (cannot import name ‘SPEED_OFF’ from ‘homeassistant.components.fan’ (/usr/src/homeassistant/homeassistant/components/fan/init.py)).
Unable to prepare setup for platform xiaomi_miot.humidifier: Platform not found (cannot import name ‘SPEED_OFF’ from ‘homeassistant.components.fan’ (/usr/src/homeassistant/homeassistant/components/fan/init.py)).
Unable to prepare setup for platform xiaomi_miot.device_tracker: Platform not found (cannot import name ‘SPEED_OFF’ from ‘homeassistant.components.fan’ (/usr/src/homeassistant/homeassistant/components/fan/init.py)).
根据你的描述,你可能遇到了一个兼容性的问题,因为SPEED_OFF这个常量在Home Assistant的新版本中已经被移除了。你可以尝试以下几种方法来解决这个问题:
  • 更新你的xiaomi_miot插件到最新版本,这个插件已经修复了这个问题12
  • 如果你不能更新插件,你可以尝试修改插件的代码,将SPEED_OFF替换为FAN_OFF3
  • 如果你不想修改代码,你可以尝试降级你的Home Assistant到2021.8.8或更早的版本。
希望这些方法能够帮助到你。
