usb z2m网关不好使
zigbee2mqtt 一直502badgateway。
什么版本的网关?运行在什么环境?具体说一下吧一般是配置不对。
zigbee3.0网关新版。
运行在haOS 已经更新到最新
你的配置有问题哦。你看看z2m那个教程,后面几楼有告诉你怎么设置端口的
大佬按照哪个教程配置后还是打不开 日志显示也不全
要改配置,看看这里
按照这个配置也是错误
你的得把ttyAMC0改为ttyUSB0
也是不对。一开始就是设置成usb0
屏幕截图_20230101_164106
大佬有空帮忙,看一下弄不明白了
还是不行呢
给你参考一下我的配置,我使用的是插网线的zigbee网关,mqtt项目里的server: mqtt://192.168.2.113/:1883 是HA盒子的IP,serial项目里的port: tcp://192.168.2.115:8888 是我zigbee网关的IP,你的172.17.0.1是盒子买来时默认的IP,应该要改。
我用的是直接接在HA上的USB 网关。 想换成像你这种插网线的。你这个是网关推荐下我也换掉
你看看你的z2m日志怎么提示
kan’bu看不懂太乱了
2023-01-02T11:08:07.242Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.243Z zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - simpleDescReq - {"dstaddr":0,"nwkaddrofinterest":0,"endpoint":3}
2023-01-02T11:08:07.243Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,37,4,0,0,0,0,3,39]
2023-01-02T11:08:07.252Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,3,4,1,5,0,0,0,0,196]
2023-01-02T11:08:07.252Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,3,4,1,5,0,0,0,0,196]
2023-01-02T11:08:07.252Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 4 - [0] - 96
2023-01-02T11:08:07.252Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - simpleDescReq - {"status":0}
2023-01-02T11:08:07.253Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,14,69,132,0,0,0,0,0,8,3,4,1,5,0,0,0,0,196]
2023-01-02T11:08:07.253Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 14 - 2 - 5 - 132 - [0,0,0,0,0,8,3,4,1,5,0,0,0,0] - 196
2023-01-02T11:08:07.253Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - simpleDescRsp - {"srcaddr":0,"status":0,"nwkaddr":0,"len":8,"endpoint":3,"profileid":260,"deviceid":5,"deviceversion":0,"numinclusters":0,"inclusterlist":[],"numoutclusters":0,"outclusterlist":[]}
2023-01-02T11:08:07.253Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.254Z zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - simpleDescReq - {"dstaddr":0,"nwkaddrofinterest":0,"endpoint":2}
2023-01-02T11:08:07.254Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,37,4,0,0,0,0,2,38]
2023-01-02T11:08:07.262Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,2,1,1,5,0,0,0,0,192]
2023-01-02T11:08:07.263Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,2,1,1,5,0,0,0,0,192]
2023-01-02T11:08:07.263Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 4 - [0] - 96
2023-01-02T11:08:07.263Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - simpleDescReq - {"status":0}
2023-01-02T11:08:07.263Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,14,69,132,0,0,0,0,0,8,2,1,1,5,0,0,0,0,192]
2023-01-02T11:08:07.263Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 14 - 2 - 5 - 132 - [0,0,0,0,0,8,2,1,1,5,0,0,0,0] - 192
2023-01-02T11:08:07.264Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - simpleDescRsp - {"srcaddr":0,"status":0,"nwkaddr":0,"len":8,"endpoint":2,"profileid":257,"deviceid":5,"deviceversion":0,"numinclusters":0,"inclusterlist":[],"numoutclusters":0,"outclusterlist":[]}
2023-01-02T11:08:07.264Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.264Z zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - simpleDescReq - {"dstaddr":0,"nwkaddrofinterest":0,"endpoint":1}
2023-01-02T11:08:07.265Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,37,4,0,0,0,0,1,37]
2023-01-02T11:08:07.273Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,1,4,1,5,0,0,0,0,198]
2023-01-02T11:08:07.273Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,4,0,96,254,14,69,132,0,0,0,0,0,8,1,4,1,5,0,0,0,0,198]
2023-01-02T11:08:07.273Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 4 - [0] - 96
2023-01-02T11:08:07.273Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - simpleDescReq - {"status":0}
2023-01-02T11:08:07.274Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,14,69,132,0,0,0,0,0,8,1,4,1,5,0,0,0,0,198]
2023-01-02T11:08:07.274Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 14 - 2 - 5 - 132 - [0,0,0,0,0,8,1,4,1,5,0,0,0,0] - 198
2023-01-02T11:08:07.274Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - simpleDescRsp - {"srcaddr":0,"status":0,"nwkaddr":0,"len":8,"endpoint":1,"profileid":260,"deviceid":5,"deviceversion":0,"numinclusters":0,"inclusterlist":[],"numoutclusters":0,"outclusterlist":[]}
2023-01-02T11:08:07.274Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.285Z zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - extNwkInfo - {}
2023-01-02T11:08:07.285Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,37,80,117]
2023-01-02T11:08:07.293Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,24,101,80,0,0,9,98,26,0,0,3,54,121,37,0,75,18,0,0,0,0,0,0,0,0,0,11,103]
2023-01-02T11:08:07.293Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,24,101,80,0,0,9,98,26,0,0,3,54,121,37,0,75,18,0,0,0,0,0,0,0,0,0,11,103]
2023-01-02T11:08:07.293Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 24 - 3 - 5 - 80 - [0,0,9,98,26,0,0,3,54,121,37,0,75,18,0,0,0,0,0,0,0,0,0,11] - 103
2023-01-02T11:08:07.294Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - extNwkInfo - {"shortaddr":0,"devstate":9,"panid":6754,"parentaddr":0,"extendedpanid":"0x00124b0025793603","parentextaddr":"0x0000000000000000","channel":11}
2023-01-02T11:08:07.294Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.309Z zigbee-herdsman:controller:log Disable joining
2023-01-02T11:08:07.317Z zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,2,2,10,0,0]}}
2023-01-02T11:08:07.319Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,26,36,2,2,253,255,0,0,0,0,0,0,242,0,0,242,33,0,1,0,30,6,0,25,2,2,10,0,0,23]
2023-01-02T11:08:07.330Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,2,0,103]
2023-01-02T11:08:07.331Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,2,0,103]
2023-01-02T11:08:07.331Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 2 - [0] - 103
2023-01-02T11:08:07.331Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequestExt - {"status":0}
2023-01-02T11:08:07.331Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.333Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,242,1,52]
2023-01-02T11:08:07.333Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,242,1,52]
2023-01-02T11:08:07.333Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,242,1] - 52
2023-01-02T11:08:07.333Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":242,"transid":1}
2023-01-02T11:08:07.334Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:08:07.535Z zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":0,"tcsignificance":0}
2023-01-02T11:08:07.535Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,5,37,54,15,252,255,0,0,26]
2023-01-02T11:08:07.543Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,54,0,82,254,3,69,182,0,0,0,240]
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,54,0,82,254,3,69,182,0,0,0,240]
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 54 - [0] - 82
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtPermitJoinReq - {"status":0}
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,69,182,0,0,0,240]
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 5 - 182 - [0,0,0] - 240
2023-01-02T11:08:07.544Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtPermitJoinRsp - {"srcaddr":0,"status":0}
2023-01-02T11:08:07.545Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:09:10.260Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,68,129,0,0,0,4,6,64,1,1,0,102,0,38,202,161,0,0,8,24,209,10,0,0,33,6,0,6,64,29]
2023-01-02T11:09:10.260Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,0,4,6,64,1,1,0,102,0,38,202,161,0,0,8,24,209,10,0,0,33,6,0,6,64,29]
2023-01-02T11:09:10.264Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [7,254,27,68,129,0,0,6,4,6,64,1,1,0,109,0,49,203,161,0,0,7,24,210,10,0,0,24,1,6,64,29]
2023-01-02T11:09:10.264Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,0,4,6,64,1,1,0,102,0,38,202,161,0,0,8,24,209,10,0,0,33,6,0,6,64,29,7,254,27,68,129,0,0,6,4,6,64,1,1,0,109,0,49,203,161,0,0,7,24,210,10,0,0,24,1,6,64,29]
2023-01-02T11:09:10.264Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,0,4,6,64,1,1,0,102,0,38,202,161,0,0,8,24,209,10,0,0,33,6,0,6,64,29] - 7
2023-01-02T11:09:10.266Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1024,"srcaddr":16390,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":102,"securityuse":0,"timestamp":10603046,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[24,209,10,0,0,33,6,0]}}
2023-01-02T11:09:10.276Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":209,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":33,"attrData":6}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":16390,"endpoint":1,"linkquality":102,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2023-01-02T11:09:10.291Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,27,68,129,0,0,6,4,6,64,1,1,0,109,0,49,203,161,0,0,7,24,210,10,0,0,24,1,6,64,29]
2023-01-02T11:09:10.292Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [41]
2023-01-02T11:09:10.292Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,27,68,129,0,0,6,4,6,64,1,1,0,109,0,49,203,161,0,0,7,24,210,10,0,0,24,1,6,64,29,41]
2023-01-02T11:09:10.292Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 27 - 2 - 4 - 129 - [0,0,6,4,6,64,1,1,0,109,0,49,203,161,0,0,7,24,210,10,0,0,24,1,6,64,29] - 41
2023-01-02T11:09:10.293Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1030,"srcaddr":16390,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":109,"securityuse":0,"timestamp":10603313,"transseqnumber":0,"len":7,"data":{"type":"Buffer","data":[24,210,10,0,0,24,1]}}
2023-01-02T11:09:10.296Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":210,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":24,"attrData":1}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":16390,"endpoint":1,"linkquality":109,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2023-01-02T11:09:10.299Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:09:17.756Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,68,129,0,0,18,0,10,101,2,1,0,167,0,61,240,168,0,0,8,24,145,10,85,0,33,2,0,10,101,29]
2023-01-02T11:09:17.757Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,18,0,10,101,2,1,0,167,0,61,240,168,0,0,8,24,145,10,85,0,33,2,0,10,101,29]
2023-01-02T11:09:17.757Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [234]
2023-01-02T11:09:17.757Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,18,0,10,101,2,1,0,167,0,61,240,168,0,0,8,24,145,10,85,0,33,2,0,10,101,29,234]
2023-01-02T11:09:17.758Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,18,0,10,101,2,1,0,167,0,61,240,168,0,0,8,24,145,10,85,0,33,2,0,10,101,29] - 234
2023-01-02T11:09:17.758Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":18,"srcaddr":25866,"srcendpoint":2,"dstendpoint":1,"wasbroadcast":0,"linkquality":167,"securityuse":0,"timestamp":11071549,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[24,145,10,85,0,33,2,0]}}
2023-01-02T11:09:17.760Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":145,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":85,"dataType":33,"attrData":2}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":25866,"endpoint":2,"linkquality":167,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2023-01-02T11:09:17.762Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:09:24.197Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,69,196,137,153,0,146]
2023-01-02T11:09:24.197Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,69,196,137,153,0,146]
2023-01-02T11:09:24.197Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 5 - 196 - [137,153,0] - 146
2023-01-02T11:09:24.198Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - srcRtgInd - {"dstaddr":39305,"relaycount":0,"relaylist":[]}
2023-01-02T11:09:24.198Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-01-02T11:09:24.213Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,100,68,129,0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40]
2023-01-02T11:09:24.214Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,100,68,129,0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40]
2023-01-02T11:09:24.215Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102]
2023-01-02T11:09:24.215Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,100,68,129,0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102]
2023-01-02T11:09:24.218Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151]
2023-01-02T11:09:24.219Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,100,68,129,0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102,33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151]
2023-01-02T11:09:24.221Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [57,77,171,50,67,137,153,29,71]
2023-01-02T11:09:24.221Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,100,68,129,0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102,33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151,57,77,171,50,67,137,153,29,71]
2023-01-02T11:09:24.221Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 100 - 2 - 4 - 129 - [0,0,192,252,137,153,1,1,0,163,0,6,24,175,0,0,80,28,95,17,53,10,247,0,65,71,3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102,33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151,57,77,171,50,67,137,153,29] - 71
2023-01-02T11:09:24.222Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":64704,"srcaddr":39305,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":163,"securityuse":0,"timestamp":11474950,"transseqnumber":0,"len":80,"data":{"type":"Buffer","data":[28,95,17,53,10,247,0,65,71,3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102,33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151,57,77,171,50,67]}}
2023-01-02T11:09:24.225Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":53,"manufacturerCode":4447,"commandIdentifier":10},"Payload":[{"attrId":247,"dataType":65,"attrData":{"type":"Buffer","data":[3,40,31,5,33,19,0,154,32,0,8,33,21,2,9,33,0,1,11,32,0,160,32,1,161,32,3,100,32,1,101,32,78,102,33,165,0,110,32,1,111,32,254,112,33,153,0,152,57,101,50,138,64,149,57,66,242,35,64,150,57,84,182,113,67,151,57,77,171,50,67]}}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":39305,"endpoint":1,"linkquality":163,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2023-01-02T11:09:24.228Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
这个日志的时间和我本地时间不一样,但是其他的日志时间是正常的
修改一下系统的时间看看,应该不是这个问题,你的事haos?什么硬件载体,是不是usb没有直通
haos j1900直接装的。之前是9.3os是好用的。升级到9.4系统后不好用了.
你退回去看看。不知道是啥掉链子了。
一般有问题的都是mqtt,端口,这两个地方。
