绿米的墙壁三键零火智能开关接入zigbee2mqtt 报一下错误
Zigbee2MQTT:error 2022-11-26 22:52:18: Failed to configure ‘客厅筒灯’, attempt 3 (Error: ConfigureReporting 0x00158d0007e2bba9/1 genOnOff([{“attribute”:“onOff”,“minimumReportInterval”:0,“maximumReportInterval”:3600,“reportableChange”:0}], {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (Status ‘UNREPORTABLE_ATTRIBUTE’)
at Endpoint.checkStatus (/app/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:196:23)
at Endpoint. (/app/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:419:26)
at Generator.next ()
at fulfilled (/app/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:24:58))
开关联动都正常,就是日志时不时会报错,请问哪位兄弟遇到过这问题,如何解决呢?
