node-red使用中遇到的问题
node red创建的自动化不执行,发现它日志出现关闭ha的连接。有dx可以帮忙解惑一下吗
下面是运行的日志
25 Nov 10:59:11 - [info] Stopped flows
25 Nov 10:59:11 - [info] Updated flows
25 Nov 10:59:11 - [info] Starting flows
25 Nov 10:59:11 - [info] Started flows
25 Nov 10:59:11 - [info] [server:Home Assistant] Connecting to http://192.168.0.8:8123
25 Nov 10:59:11 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Close
25 Nov 10:59:11 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT End
25 Nov 10:59:11 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Connected
25 Nov 10:59:11 - [info] [zigbee2mqtt-server:zigbee2mqtt] Refreshing devices
25 Nov 10:59:11 - [info] [mqtt-broker:mqtt] Connected to broker: mqtt://192.168.0.8:1883
25 Nov 10:59:11 - [info] [server:Home Assistant] Connected to http://192.168.0.8:8123
25 Nov 10:59:11 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Subscribed to: "zigbee2mqtt/#
25 Nov 10:59:21 - [info] [zigbee2mqtt-server:zigbee2mqtt] Using cached devices
25 Nov 11:01:39 - [info] Stopping flows
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Unsubscribe from mqtt topic: zigbee2mqtt/#
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT connection closed
25 Nov 11:01:39 - [info] [server:Home Assistant] Closing connection to http://192.168.0.8:8123
25 Nov 11:01:39 - [info] Stopped flows
25 Nov 11:01:39 - [info] Updated flows
25 Nov 11:01:39 - [info] Starting flows
25 Nov 11:01:39 - [info] Started flows
25 Nov 11:01:39 - [info] [server:Home Assistant] Connecting to http://192.168.0.8:8123
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Close
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT End
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Connected
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] Refreshing devices
25 Nov 11:01:39 - [info] [mqtt-broker:mqtt] Connected to broker: mqtt://192.168.0.8:1883
25 Nov 11:01:39 - [info] [server:Home Assistant] Connected to http://192.168.0.8:8123
25 Nov 11:01:39 - [info] [zigbee2mqtt-server:zigbee2mqtt] MQTT Subscribed to: "zigbee2mqtt/#
Received event for unknown subscription 4. Unsubscribing.
Received event for unknown subscription 10. Unsubscribing.
我也有同样的问题,一直未找到原因
{“log”:“Received event for unknown subscription 2. Unsubscribing.\r\n”,“stream”:“stdout”,“time”:“2022-12-20T09:51:06.159388371Z”}
{“log”:“Received event for unknown subscription 7. Unsubscribing.\r\n”,“stream”:“stdout”,“time”:“2022-12-20T09:51:06.164840632Z”}
