盒子无法进入端口8123控制台,端口3000可以进入,容器里homeassistant总是自动停止,启动后还是进不去8123,用不了几分钟,homeassistant又会自动关闭。
日志如下:
022-11-22 23:48:50 ERROR (SyncWorker_0) [homeassistant.util.json] Could not parse JSON content: /config/.storage/core.config_entries
File “/usr/src/homeassistant/homeassistant/util/json.py”, line 33, in load_json
return json.loads(fdesc.read()) # type: ignore[no-any-return]
File “/usr/local/lib/python3.9/json/init.py”, line 346, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.9/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/local/lib/python3.9/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2022-11-22 23:48:50 ERROR (MainThread) [root] Uncaught exception
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.9/runpy.py”, line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/local/lib/python3.9/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 203, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 191, in main
exit_code = runner.run(runtime_conf)
File “/usr/src/homeassistant/homeassistant/runner.py”, line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 642, in run_until_complete
return future.result()
File “/usr/src/homeassistant/homeassistant/runner.py”, line 101, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 138, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 219, in async_from_config_dict
await hass.config_entries.async_initialize()
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 914, in async_initialize
config = await self.hass.helpers.storage.async_migrator(
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 42, in async_migrator
if (store_data := await store.async_load()) is not None:
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 114, in async_load
return await self._load_task
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 123, in _async_load
return await self._async_load_data()
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 141, in _async_load_data
data = await self.hass.async_add_executor_job(
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 58, in run
result = self.fn(*self.args, **self.kwargs)
File “/usr/src/homeassistant/homeassistant/util/json.py”, line 39, in load_json
raise HomeAssistantError(error) from error
homeassistant.exceptions.HomeAssistantError: Expecting value: line 1 column 1 (char 0)
什么时候的版本的盒子?
进入3000管理界面,你看看那个镜像里面的supervisor版本是多少?截图看看
已经按教程 删除 然后自动更新 目前还未出来版本好 只是显示landingpage,是正常现象吧
landing表示在下载。
你的版本太旧了。你截图全屏,镜像那页给我们看看,后面提供截屏要全屏,你这样我们都看不清其他的
这个得看你的出国的网络。一般半个小时左右。
家里有特殊网络环境,是n1盒子,但是n1设备只有wifi信号,是不是把智趣盒子想办法连上n1的网络环境就可以下载的更快一点,智趣盒子又不很好操作wifi连接,有没有什么别的办法可以更快的完成下载,目前等了2个小时,还是没能下载完。
没变化 还是那个状态
手动更新的话 如何知道最新的版本号呢
目前的版本号用2022.11.4
你手动应该也是一样的。
这个没有本地倒入的。你要在路由器层面,然后盒子出国。就是卡在github拉镜像回来这步骤。你放着,然后等它更新完整吧
1,盒子出国只能靠wifi连接,家里的旁路由是可以出国的,但是没有网线插口,是网上买的n1斐讯盒子刷的。robot有建议在我家里这种环境下让盒子出国的办法吗?
2,“你放着,然后等它更新完整吧”是说,在不让盒子出国的情况下,这样等着,只是慢,最终也会下载完是吧,需要的只是时间
盒子出国不一定要靠Wi-Fi啊,你的n1是旁路?那你也是把它介入了局域网吧?你可以在openwrt里面指定盒子全局出国。
如果不会搞,你放着,慢慢拉,一般会下载完的,就是时间的问题。
先耐心等待。谢谢。
