智米智能电暖器
This is a custom component for home assistant to integrate the Smartmi smart heater.
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml file.
Credits: Thanks to Rytilahti for all the work.
Features
viomi.health_pot.v1
- Sensors
- hvac_modes: heat,off
- min_temp
- max_temp
- target_temp_step
- current_temperature
- temperature
- curr_tempe
- power
- humidity
- target_temperature
- Chart
- Temperature History
- Services
- set_hvac_mode
- set_temperature
Setup
# configuration.yaml
climate:
- platform: miheater
host: 192.168.1.13
token: a9bd32552dc9bd4e156954c20ddbcb38
Configuration variables:
- host (Required): The IP of your cooker.
- token (Required): The API token of your cooker.
- name (Optional): The name of your cooker.
Platform services
Service climate.set_hvac_mode
Specify the heater mode.
| Service data attribute | Optional | Description |
entity_id |
yes | Only act on a specific heater. |
hvac_mode |
yes | Specify the heater mode (heat/off). |
Service climate.set_temperature
Set the temperature of heater.
entity_id |
temperature |
yes | Set the temperature of heater. |
