[18:09:00] INFO: Preparing to start…
[18:09:00] INFO: Socat not enabled
[18:09:02] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2022-11-02 18:09:08: Logging to console and directory: ‘/share/zigbee2mqtt/log/2022-11-02.18-09-08’ filename: log.txt
Zigbee2MQTT:info 2022-11-02 18:09:08: Starting Zigbee2MQTT version 1.28.0 (commit #unknown)
Zigbee2MQTT:info 2022-11-02 18:09:08: Starting zigbee-herdsman (0.14.62)
Zigbee2MQTT:error 2022-11-02 18:09:29: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-11-02 18:09:29: Failed to start zigbee
Zigbee2MQTT:error 2022-11-02 18:09:29: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2022-11-02 18:09:29: Exiting…
Zigbee2MQTT:error 2022-11-02 18:09:29: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:109:5)
你提供一下,下面几个信息:
1.在8123管理界面,配置,系统,硬件,点击三个点,截图给我们看看。
2.在8123管理界面,配置,加载项,然后zigbee2mqtt,配置,截图你的z2m配置给我们。
萝卜没上来。
你的是wifi网关还是usb的?
