| ham.0 |
2020-04-05 00:10:03.902 |
info |
Install/Update homebridge-mqtt-zdc1 |
| ham.0 |
2020-04-05 00:10:03.901 |
info |
Install/Update the following Libraries: homebridge-mqtt-zdc1 |
| ham.0 |
2020-04-05 00:10:03.839 |
info |
found 0 vulnerabilities |
| ham.0 |
2020-04-05 00:10:03.834 |
info |
+ homebridge@0.4.50 updated 1 package and audited 7056 packages in 41.971s |
| ham.0 |
2020-04-05 00:09:46.727 |
info |
WARN deprecated mkdirp@0.3.5: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.) |
| ham.0 |
2020-04-05 00:09:46.725 |
info |
npm |
| ham.0 |
2020-04-05 00:09:18.464 |
info |
npm install homebridge@0.4.50 --production --prefix “/opt/iobroker/node_modules/iobroker.ham” (System call) |
| ham.0 |
2020-04-05 00:09:18.462 |
info |
Need to install/update homebridge@0.4.50 |
| ham.0 |
2020-04-05 00:09:18.406 |
info |
starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v8.16.0 |
| host.aml |
2020-04-05 00:09:17.074 |
info |
instance system.adapter.ham.0 started with pid 4922 |
| host.aml |
2020-04-05 00:09:17.060 |
info |
object change system.adapter.ham.0 |
| host.aml |
2020-04-05 00:09:15.084 |
info |
Restart adapter system.adapter.ham.0 because enabled |
| host.aml |
2020-04-05 00:09:15.083 |
error |
instance system.adapter.ham.0 terminated with code 0 (OK) |
| Caught |
error |
by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:227:5) |
| Caught |
error |
by controller[2]: at doWrite (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:237:10) |
| Caught |
error |
by controller[2]: at Writable.writable._write (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:248:5) |
| Caught |
2020-04-05 00:09:15.082 |
error |
by controller[2]: at process (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:238:12) |
| Caught |
error |
by controller[2]: at MqttClient._handlePacket (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:282:12) |
| Caught |
error |
by controller[2]: at MqttClient._handlePublish (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:792:12) |
| Caught |
error |
by controller[2]: at MqttClient.emit (events.js:217:7) |
| Caught |
2020-04-05 00:09:15.081 |
error |
by controller[2]: at emitThree (events.js:136:13) |
| Caught |
error |
by controller[2]: at MqttClient. (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mqtt-zdc1/index.js:81:17) |
| Caught |
error |
by controller[2]: at JSON.parse () |
| Caught |
error |
by controller[2]: SyntaxError: Unexpected end of JSON input |
| Caught |
2020-04-05 00:09:15.080 |
error |
by controller[1]: [2020-4-5 00:09:11] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword ‘homebridge-plugin’. |
| Caught |
2020-04-05 00:09:15.079 |
error |
by controller[0]: [2020-4-5 00:09:10] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword ‘homebridge-plugin’. |
| mqtt.0 |
2020-04-05 00:09:15.073 |
info |
Client [mqttjs_eb5bb167] connection closed: closed |
| ham.0 |
2020-04-05 00:09:14.846 |
warn |
Exception: SyntaxError: Unexpected end of JSON input |
| ham.0 |
2020-04-05 00:09:14.827 |
info |
cleaned everything up… |
| ham.0 |
2020-04-05 00:09:14.824 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
| ham.0 |
error |
at JSON.parse () |
| ham.0 |
error |
| ham.0 |
2020-04-05 00:09:14.823 |
error |
uncaught exception: Unexpected end of JSON input |
| ham.0 |
2020-04-05 00:09:14.361 |
info |
updateState 斐讯排插.斐讯排插s3.Name: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.360 |
info |
updateState 斐讯排插.斐讯排插s3.Outlet-In-Use: value = false /common= {“type”:“boolean”,“read”:true,“write”:false,“role”:“sensor”,“name”:“Outlet In Use”,“unit”:""} |
| ham.0 |
info |
updateState 斐讯排插.斐讯排插s3.On: value = false /common= {“type”:“boolean”,“read”:true,“write”:true,“role”:“switch”,“name”:“On”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.359 |
info |
updateState 斐讯排插.斐讯排插s3.Name: value = 斐讯排插s3 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.358 |
info |
updateChannel 斐讯排插.斐讯排插s3: name = 斐讯排插s3 |
| ham.0 |
2020-04-05 00:09:14.357 |
info |
updateState 斐讯排插.斐讯排插s2.Name: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
info |
updateState 斐讯排插.斐讯排插s2.Outlet-In-Use: value = false /common= {“type”:“boolean”,“read”:true,“write”:false,“role”:“sensor”,“name”:“Outlet In Use”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.356 |
info |
updateState 斐讯排插.斐讯排插s2.On: value = false /common= {“type”:“boolean”,“read”:true,“write”:true,“role”:“switch”,“name”:“On”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.355 |
info |
updateState 斐讯排插.斐讯排插s2.Name: value = 斐讯排插s2 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
info |
updateChannel 斐讯排插.斐讯排插s2: name = 斐讯排插s2 |
| ham.0 |
2020-04-05 00:09:14.354 |
info |
updateState 斐讯排插.斐讯排插s1.Name: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.353 |
info |
updateState 斐讯排插.斐讯排插s1.Outlet-In-Use: value = false /common= {“type”:“boolean”,“read”:true,“write”:false,“role”:“sensor”,“name”:“Outlet In Use”,“unit”:""} |
| ham.0 |
info |
updateState 斐讯排插.斐讯排插s1.On: value = false /common= {“type”:“boolean”,“read”:true,“write”:true,“role”:“switch”,“name”:“On”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.352 |
info |
updateState 斐讯排插.斐讯排插s1.Name: value = 斐讯排插s1 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.351 |
info |
updateChannel 斐讯排插.斐讯排插s1: name = 斐讯排插s1 |
| ham.0 |
2020-04-05 00:09:14.350 |
info |
updateState 斐讯排插.斐讯排插.Name: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
info |
updateState 斐讯排插.斐讯排插.Outlet-In-Use: value = false /common= {“type”:“boolean”,“read”:true,“write”:false,“role”:“sensor”,“name”:“Outlet In Use”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.349 |
info |
updateState 斐讯排插.斐讯排插.On: value = false /common= {“type”:“boolean”,“read”:true,“write”:true,“role”:“switch”,“name”:“On”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.348 |
info |
updateState 斐讯排插.斐讯排插.Name: value = 斐讯排插 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.347 |
info |
updateChannel 斐讯排插.斐讯排插: name = 斐讯排插 |
| ham.0 |
2020-04-05 00:09:14.346 |
info |
updateState 斐讯排插.Accessory-Information.Accessory-Flags: value = 0 /common= {“type”:“number”,“min”:0,“max”:4294967295,“read”:true,“write”:false,“role”:“value”,“name”:“Accessory Flags”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.345 |
info |
updateState 斐讯排插.Accessory-Information.Hardware-Revision: value = /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Hardware Revision”,“unit”:""} |
| ham.0 |
info |
updateState 斐讯排插.Accessory-Information.Firmware-Revision: value = 1.0 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Firmware Revision”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.344 |
info |
updateState 斐讯排插.Accessory-Information.Serial-Number: value = hassbian-ABC /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Serial Number”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.343 |
info |
updateState 斐讯排插.Accessory-Information.Name: value = 斐讯排插 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Name”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.342 |
info |
updateState 斐讯排插.Accessory-Information.Model: value = phicomm_dc1 /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Model”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.341 |
info |
updateState 斐讯排插.Accessory-Information.Manufacturer: value = phicomm /common= {“type”:“string”,“read”:true,“write”:false,“role”:“text”,“name”:“Manufacturer”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.340 |
info |
updateState 斐讯排插.Accessory-Information.Identify: value = false /common= {“type”:“boolean”,“read”:false,“write”:true,“role”:“button”,“name”:“Identify”,“unit”:""} |
| ham.0 |
2020-04-05 00:09:14.335 |
info |
updateChannel 斐讯排插.Accessory-Information: name = undefined |
| ham.0 |
2020-04-05 00:09:14.331 |
info |
updateDev 斐讯排插: name = 斐讯排插 /type= 1 |
| mqtt.0 |
2020-04-05 00:09:14.727 |
info |
Client [mqttjs_eb5bb167] publishOnSubscribe |
| mqtt.0 |
2020-04-05 00:09:14.726 |
info |
Client [mqttjs_eb5bb167] subscribes on “mqtt.0.device.zdc1.84f3ebbaad13.state” |
| ham.0 |
2020-04-05 00:09:09.153 |
info |
All Libraries installed/updated |
| ham.0 |
2020-04-05 00:09:09.152 |
info |
| ham.0 |
2020-04-05 00:09:09.151 |
info |
| ham.0 |
2020-04-05 00:09:09.147 |
info |
| mqtt.0 |
2020-04-05 00:09:14.643 |
info |
Client [mqttjs_eb5bb167] connected with secret 1586016554556_1033 |
| ham.0 |
2020-04-05 00:09:09.093 |
info |
| host.aml |
2020-04-05 00:09:07.661 |
info |
instance system.adapter.ham.0 started with pid 4888 |
