手动删除/usr/share/hassio 文件,重新安装后可以正常启动了!
有可能是你的配置文件下载的时候丢失了某些东西,或者你自定义配置文件出了问题。我昨天应该又说删掉那些文件重启。
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 34.0494
longitude: -118.2641
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Los_Angeles
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
sensor:
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
molohub:
dismissable:true
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
homeassistant:
packages: !include_dir_named packages
你的代码编辑工具,我建议用sublime text3。自己百度一下,你用记事本打开很容易格式和编码错误。你们家的ha对格式要求很高。
试试我刚刚说的那个看看。
嗯,好的!hassio和iobroker不冲突吧,安装体验下
冲突。不能装在同一部机子上。因为大家都是平台级的,端口可能会互相占用。
你们家的HA?我该笑吗
