本节点支持不通过HA来中转控制控客设备,并且配合dashboard能支持很好的可视化和联动
1.0.3修订
1、支持对于相同动作不重复操作
2、支持免填写密码和mac地址
控客的nodered节点
提供发现和操作两个节点
发现节点用于发现内网可操作的控客开关,获取相关信息用于操作节点操作用
操作节点用于直接操作配置好的控客开关,同时也提供去检查指定开关状态的功能
基于以上两个功能可完成局域网控客开关的操作
安装
# 去nodered目录
npm i node-red-contrib-konkeio
nodered 范例流
请直接导入使用
"id": "211b19ee.7070b6",
"type": "konkeio-discover",
"z": "4cc2a712.3a16e8",
"timeout": 1000,
"x": 670,
"y": 180,
"wires": [
"ad5e51c5.80441"
"id": "6ed3bee1.0d6b4",
"type": "inject",
"name": "",
"topic": "",
"payload": "",
"payloadType": "date",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 505,
"y": 180,
"wires": [
"211b19ee.7070b6"
"id": "ad5e51c5.80441",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 830,
"y": 180,
"wires": []
"id": "1fa33e97.04d741",
"type": "inject",
"name": "",
"topic": "",
"payload": "",
"repeat": "2",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 520,
"y": 240,
"wires": [
"f9ef7874.cbfdf8"
"id": "f9ef7874.cbfdf8",
"type": "konkeio-action",
"name": "检测",
"ip": "192.168.200.236",
"sw": "check",
"x": 670,
"y": 240,
"wires": [
"7249e928.996fe8"
"id": "7249e928.996fe8",
"type": "ui_switch",
"name": "",
"label": "插座",
"tooltip": "",
"group": "72a893e.0d55c6c",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"decouple": "false",
"topic": "",
"style": "",
"onvalue": "true",
"onvalueType": "bool",
"onicon": "",
"oncolor": "",
"offvalue": "false",
"offvalueType": "bool",
"officon": "",
"offcolor": "",
"x": 825,
"y": 240,
"wires": [
"6bcbe79f.53fe38"
"id": "6bcbe79f.53fe38",
"name": "操作",
"sw": "auto",
"x": 970,
"y": 240,
"wires": [
"f9510104.f2b0e"
"id": "f9510104.f2b0e",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1110,
"y": 240,
"wires": []
"id": "72a893e.0d55c6c",
"type": "ui_group",
"name": "插座组",
"tab": "1d6cc3f8.a0bbbc",
"order": 2,
"disp": true,
"width": "6",
"collapse": false
"id": "1d6cc3f8.a0bbbc",
"type": "ui_tab",
"name": "我的家",
"icon": "group",
"order": 2,
"disabled": false,
"hidden": false
