已经设置了简体中文,并且在刚安装好的时候是可以显示中文的。后来不知道怎么就不行了。下面是日志。并且易微联不知道怎么回事也一直联不上。
admin.0 2021-10-24 22:19:09.436 info Use link “http://localhost:8081” to configure.
admin.0 2021-10-24 22:19:09.435 info http server listening on port 8081
admin.0 2021-10-24 22:19:09.288 info received all objects
admin.0 2021-10-24 22:19:09.022 info requesting all objects
admin.0 2021-10-24 22:19:09.021 info requesting all states
admin.0 2021-10-24 22:19:08.973 info starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 22:19:06.707 info instance system.adapter.admin.0 started with pid 3653
host.iobroker2 2021-10-24 22:19:04.178 info instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 22:19:03.662 info stopInstance system.adapter.admin.0 send kill signal
admin.0 2021-10-24 22:19:03.627 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
admin.0 2021-10-24 22:19:03.625 info terminating
admin.0 2021-10-24 22:19:03.624 info terminating http server on port 8081
admin.0 2021-10-24 22:19:03.618 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 22:19:03.606 info stopInstance system.adapter.admin.0 (force=false, process=true)
info.0 2021-10-24 22:15:22.310 info cpu Temp res = {“main”:36,“cores”:[35,35,36,36],“max”:36,“socket”:[],“chipset”:null}
info.0 2021-10-24 22:15:22.140 info State value to set for “info.0.sysinfo.cpu.info.cache-l3” has to be type “number” but received type “string”
info.0 2021-10-24 22:15:21.928 info State value to set for “info.0.sysinfo.cpu.info.speed” has to be type “string” but received type “number”
info.0 2021-10-24 22:15:21.473 info Reading/updating systemdata.
info.0 2021-10-24 22:15:21.418 info starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 22:15:18.637 info instance system.adapter.info.0 started with pid 3236
host.iobroker2 2021-10-24 22:15:18.566 info iobroker npm-install: exit 0
host.iobroker2 2021-10-24 22:15:17.498 info iobroker npm-install: host.iobroker2 object system.adapter.info created/updated
host.iobroker2 2021-10-24 22:15:17.388 info iobroker npm-install: upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
host.iobroker2 2021-10-24 22:15:17.330 info iobroker npm-install: upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
host.iobroker2 2021-10-24 22:15:17.269 info iobroker npm-install: upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
host.iobroker2 2021-10-24 22:15:17.211 info iobroker npm-install: upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
host.iobroker2 2021-10-24 22:15:17.153 info iobroker npm-install: upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
host.iobroker2 2021-10-24 22:15:17.096 info iobroker npm-install: upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
host.iobroker2 2021-10-24 22:15:17.036 info iobroker npm-install: upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
host.iobroker2 2021-10-24 22:15:16.979 info iobroker npm-install: upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
host.iobroker2 2021-10-24 22:15:16.919 info iobroker npm-install: upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
host.iobroker2 2021-10-24 22:15:16.859 info iobroker npm-install: upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
host.iobroker2 2021-10-24 22:15:16.792 info iobroker npm-install: upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
host.iobroker2 2021-10-24 22:15:16.730 info iobroker npm-install: upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
host.iobroker2 2021-10-24 22:15:16.665 info iobroker npm-install: upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
host.iobroker2 2021-10-24 22:15:16.286 info iobroker npm-install: upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
host.iobroker2 2021-10-24 22:15:16.219 info iobroker npm-install: upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
host.iobroker2 2021-10-24 22:15:16.161 info iobroker npm-install: upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
host.iobroker2 2021-10-24 22:15:16.103 info iobroker npm-install: upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
host.iobroker2 2021-10-24 22:15:16.045 info iobroker npm-install: upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
host.iobroker2 2021-10-24 22:15:15.987 info iobroker npm-install: upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/audio.png lib/img/icons/audio.png image/png
host.iobroker2 2021-10-24 22:15:15.930 info iobroker npm-install: upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
host.iobroker2 2021-10-24 22:15:15.872 info iobroker npm-install: upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/bluetooth.png lib/img/icons/bluetooth.png image/png
host.iobroker2 2021-10-24 22:15:15.304 info iobroker npm-install: upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/usb.png lib/img/icons/usb.png image/png
host.iobroker2 2021-10-24 22:15:14.450 info iobroker npm-install: upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/freebsd.png lib/img/logos/freebsd.png image/png
host.iobroker2 2021-10-24 22:15:13.862 info iobroker npm-install: upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/pclinuxos.png lib/img/logos/pclinuxos.png image/png
host.iobroker2 2021-10-24 22:15:13.277 info iobroker npm-install: upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/xubuntu.png lib/img/logos/xubuntu.png image/png
host.iobroker2 2021-10-24 22:15:12.708 info iobroker npm-install: upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
host.iobroker2 2021-10-24 22:15:12.139 info iobroker npm-install: upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
host.iobroker2 2021-10-24 22:15:11.714 info iobroker npm-install: host.iobroker2 install adapter info@1.9.8
host.iobroker2 2021-10-24 22:14:48.911 info iobroker npm-install: npm install iobroker.info@1.9.8 --loglevel error --prefix “/opt/iobroker” (System call)
host.iobroker2 2021-10-24 22:14:48.908 info iobroker npm-install: NPM version: 6.14.15
discovery.0 2021-10-24 22:14:47.292 info starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 22:14:46.475 info iobroker install info@1.9.8 using installedFrom
host.iobroker2 2021-10-24 22:14:46.474 warn startInstance cannot find adapter “info@1.9.8”. Try to install it… 1 attempt
host.iobroker2 2021-10-24 22:14:45.494 info instance system.adapter.discovery.0 started with pid 3185
host.iobroker2 2021-10-24 22:14:45.470 info iobroker npm-install: exit 0
host.iobroker2 2021-10-24 22:14:44.410 info iobroker npm-install: host.iobroker2 object system.adapter.discovery created/updated
host.iobroker2 2021-10-24 22:14:44.302 info iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
host.iobroker2 2021-10-24 22:14:44.243 info iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
host.iobroker2 2021-10-24 22:14:44.183 info iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
host.iobroker2 2021-10-24 22:14:44.126 info iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
host.iobroker2 2021-10-24 22:14:44.068 info iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
host.iobroker2 2021-10-24 22:14:44.010 info iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
host.iobroker2 2021-10-24 22:14:43.920 info iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
host.iobroker2 2021-10-24 22:14:43.897 info iobroker npm-install: host.iobroker2 install adapter discovery@2.7.0
node-red.0 2021-10-24 22:14:09.846 warn 24 Oct 22:14:09 - [warn] Projects disabled : editorTheme.projects.enabled=false
admin.0 2021-10-24 22:14:05.074 info Use link “http://localhost:8081” to configure.
admin.0 2021-10-24 22:14:05.073 info http server listening on port 8081
node-red.0 2021-10-24 22:14:04.874 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
admin.0 2021-10-24 22:14:04.870 info received all objects
host.iobroker2 2021-10-24 22:14:04.629 info iobroker npm-install: NPM version: 6.14.15npm install iobroker.discovery@2.7.0 --loglevel error --prefix “/opt/iobroker” (System call)
admin.0 2021-10-24 22:14:04.583 info requesting all objects
admin.0 2021-10-24 22:14:04.582 info requesting all states
admin.0 2021-10-24 22:14:04.524 info starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.7, js-controller: 3.3.18
node-red.0 2021-10-24 22:14:04.513 info starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.7, js-controller: 3.3.18
sonoff.0 2021-10-24 22:14:04.432 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 22:14:04.346 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 22:14:03.023 info instance system.adapter.node-red.0 started with pid 2978
host.iobroker2 2021-10-24 22:14:02.152 info instance system.adapter.sonoff.0 started with pid 2971
host.iobroker2 2021-10-24 22:14:01.875 info iobroker install discovery@2.7.0 using installedFrom
host.iobroker2 2021-10-24 22:14:01.874 warn startInstance cannot find adapter “discovery@2.7.0”. Try to install it… 1 attempt
host.iobroker2 2021-10-24 22:14:01.813 info instance system.adapter.admin.0 started with pid 2957
host.iobroker2 2021-10-24 22:14:00.520 info instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
node-red.0 2021-10-24 22:13:59.991 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
host.iobroker2 2021-10-24 22:13:59.985 info stopInstance timeout 1000 system.adapter.node-red.0 killing pid 2922
host.iobroker2 2021-10-24 22:13:59.625 info instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 22:13:59.454 info instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 22:13:59.373 info instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 22:13:59.348 info instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 22:13:59.121 info stopInstance system.adapter.sonoff.0 send kill signal
sonoff.0 2021-10-24 22:13:59.088 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.0 2021-10-24 22:13:59.086 info terminating
sonoff.0 2021-10-24 22:13:59.082 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 22:13:59.078 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
node-red.0 2021-10-24 22:13:59.008 info node-red exited with 0
node-red.0 2021-10-24 22:13:58.987 info kill node-red task
host.iobroker2 2021-10-24 22:13:58.983 info stopInstance system.adapter.node-red.0 (force=false, process=true)
host.iobroker2 2021-10-24 22:13:58.956 info stopInstance system.adapter.info.0 send kill signal
info.0 2021-10-24 22:13:58.922 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
info.0 2021-10-24 22:13:58.920 info terminating
info.0 2021-10-24 22:13:58.919 info cleaned everything up…
info.0 2021-10-24 22:13:58.917 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 22:13:58.913 info stopInstance system.adapter.info.0 (force=false, process=true)
host.iobroker2 2021-10-24 22:13:58.854 info stopInstance system.adapter.discovery.0 send kill signal
discovery.0 2021-10-24 22:13:58.818 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
discovery.0 2021-10-24 22:13:58.816 info terminating
discovery.0 2021-10-24 22:13:58.815 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 22:13:58.811 info stopInstance system.adapter.discovery.0 (force=false, process=true)
host.iobroker2 2021-10-24 22:13:58.769 info stopInstance system.adapter.admin.0 send kill signal
admin.0 2021-10-24 22:13:58.738 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
admin.0 2021-10-24 22:13:58.736 info terminating
admin.0 2021-10-24 22:13:58.735 info terminating http server on port 8081
admin.0 2021-10-24 22:13:58.729 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 22:13:58.720 info stopInstance system.adapter.admin.0 (force=false, process=true)
node-red.0 2021-10-24 21:51:19.977 warn 24 Oct 21:51:19 - [warn] Projects disabled : editorTheme.projects.enabled=false
node-red.0 2021-10-24 21:51:15.309 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
node-red.0 2021-10-24 21:51:15.127 info starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 21:51:13.963 info instance system.adapter.node-red.0 started with pid 2922
host.iobroker2 2021-10-24 21:51:11.950 info iobroker exit 0
host.iobroker2 2021-10-24 21:51:10.929 info iobroker host.iobroker2 object system.adapter.node-red.0 created
host.iobroker2 2021-10-24 21:51:10.886 info iobroker host.iobroker2 object system.adapter.node-red.0.alive created
host.iobroker2 2021-10-24 21:51:10.857 info iobroker host.iobroker2 object system.adapter.node-red.0.connected created
host.iobroker2 2021-10-24 21:51:10.828 info iobroker host.iobroker2 object system.adapter.node-red.0.compactMode created
host.iobroker2 2021-10-24 21:51:10.799 info iobroker host.iobroker2 object system.adapter.node-red.0.cpu created
host.iobroker2 2021-10-24 21:51:10.769 info iobroker host.iobroker2 object system.adapter.node-red.0.cputime created
host.iobroker2 2021-10-24 21:51:10.740 info iobroker host.iobroker2 object system.adapter.node-red.0.memHeapUsed created
host.iobroker2 2021-10-24 21:51:10.711 info iobroker host.iobroker2 object system.adapter.node-red.0.memHeapTotal created
host.iobroker2 2021-10-24 21:51:10.682 info iobroker host.iobroker2 object system.adapter.node-red.0.memRss created
host.iobroker2 2021-10-24 21:51:10.652 info iobroker host.iobroker2 object system.adapter.node-red.0.uptime created
host.iobroker2 2021-10-24 21:51:10.623 info iobroker host.iobroker2 object system.adapter.node-red.0.inputCount created
host.iobroker2 2021-10-24 21:51:10.594 info iobroker host.iobroker2 object system.adapter.node-red.0.outputCount created
host.iobroker2 2021-10-24 21:51:10.565 info iobroker host.iobroker2 object system.adapter.node-red.0.eventLoopLag created
host.iobroker2 2021-10-24 21:51:10.536 info iobroker host.iobroker2 object system.adapter.node-red.0.sigKill created
host.iobroker2 2021-10-24 21:51:10.506 info iobroker host.iobroker2 object system.adapter.node-red.0.logLevel created
host.iobroker2 2021-10-24 21:51:10.477 info iobroker host.iobroker2 object node-red.0 created
host.iobroker2 2021-10-24 21:51:10.471 info iobroker host.iobroker2 create instance node-red
host.iobroker2 2021-10-24 21:51:10.426 info iobroker host.iobroker2 object system.adapter.node-red created/updated
host.iobroker2 2021-10-24 21:51:10.325 info iobroker upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
host.iobroker2 2021-10-24 21:51:10.268 info iobroker upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
host.iobroker2 2021-10-24 21:51:10.211 info iobroker upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
host.iobroker2 2021-10-24 21:51:10.154 info iobroker upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
host.iobroker2 2021-10-24 21:51:10.097 info iobroker upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
host.iobroker2 2021-10-24 21:51:10.033 info iobroker upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.975 info iobroker upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.917 info iobroker upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.859 info iobroker upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.801 info iobroker upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.743 info iobroker upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
host.iobroker2 2021-10-24 21:51:09.683 info iobroker upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
host.iobroker2 2021-10-24 21:51:09.624 info iobroker upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
host.iobroker2 2021-10-24 21:51:09.566 info iobroker upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
host.iobroker2 2021-10-24 21:51:09.482 info iobroker upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
host.iobroker2 2021-10-24 21:51:09.449 info iobroker host.iobroker2 install adapter node-red
host.iobroker2 2021-10-24 21:43:36.073 info iobroker npm install iobroker.node-red@2.4.0 --loglevel error --unsafe-perm --prefix “/opt/iobroker” (System call)
host.iobroker2 2021-10-24 21:43:36.060 info iobroker NPM version: 6.14.15
host.iobroker2 2021-10-24 21:43:33.665 info iobroker add node-red auto --host iobroker2
sonoff.0 2021-10-24 21:40:21.658 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 21:40:21.609 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 21:40:20.152 info instance system.adapter.sonoff.0 started with pid 2576
host.iobroker2 2021-10-24 21:40:17.625 info instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 21:40:17.126 info stopInstance system.adapter.sonoff.0 send kill signal
sonoff.0 2021-10-24 21:40:17.087 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.0 2021-10-24 21:40:17.085 info terminating
sonoff.0 2021-10-24 21:40:17.082 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 21:40:17.078 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
sonoff.0 2021-10-24 20:52:28.894 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 20:52:28.843 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 20:52:27.357 info instance system.adapter.sonoff.0 started with pid 2541
host.iobroker2 2021-10-24 20:52:24.835 info instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 20:52:24.333 info stopInstance system.adapter.sonoff.0 send kill signal
sonoff.0 2021-10-24 20:52:24.299 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.0 2021-10-24 20:52:24.297 info terminating
sonoff.0 2021-10-24 20:52:24.294 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 20:52:24.290 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
sonoff.0 2021-10-24 20:52:18.802 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 20:52:18.750 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 20:52:17.242 info instance system.adapter.sonoff.0 started with pid 2526
host.iobroker2 2021-10-24 20:52:15.834 info instance system.adapter.sonoff.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
sonoff.0 2021-10-24 20:52:15.225 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
host.iobroker2 2021-10-24 20:52:15.218 info stopInstance system.adapter.sonoff.0 killing pid 2511
sonoff.0 2021-10-24 20:52:14.742 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 20:52:14.693 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 20:52:14.217 info stopInstance system.adapter.sonoff.0 send kill signal
host.iobroker2 2021-10-24 20:52:14.172 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
host.iobroker2 2021-10-24 20:52:13.219 info instance system.adapter.sonoff.0 started with pid 2511
host.iobroker2 2021-10-24 20:52:10.717 info instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 20:52:10.193 info stopInstance system.adapter.sonoff.0 send kill signal
sonoff.0 2021-10-24 20:52:10.159 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.0 2021-10-24 20:52:10.157 info terminating
sonoff.0 2021-10-24 20:52:10.154 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 20:52:10.149 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
sonoff.0 2021-10-24 20:52:02.999 info Starting MQTT authenticated server on port 1883
sonoff.0 2021-10-24 20:52:02.951 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 20:52:01.452 info instance system.adapter.sonoff.0 started with pid 2496
host.iobroker2 2021-10-24 20:51:58.929 info instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.iobroker2 2021-10-24 20:51:58.424 info stopInstance system.adapter.sonoff.0 send kill signal
sonoff.0 2021-10-24 20:51:58.390 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.0 2021-10-24 20:51:58.388 info terminating
sonoff.0 2021-10-24 20:51:58.385 info Got terminate signal TERMINATE_YOURSELF
host.iobroker2 2021-10-24 20:51:58.380 info stopInstance system.adapter.sonoff.0 (force=false, process=true)
sonoff.0 2021-10-24 20:51:45.306 info Starting MQTT server on port 1883
sonoff.0 2021-10-24 20:51:45.259 info starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.7, js-controller: 3.3.18
host.iobroker2 2021-10-24 20:51:43.662 info instance system.adapter.sonoff.0 started with pid 2481
host.iobroker2 2021-10-24 20:51:41.645 info iobroker exit 0
host.iobroker2 2021-10-24 20:51:40.623 info iobroker host.iobroker2 object system.adapter.sonoff.0 created
host.iobroker2 2021-10-24 20:51:40.581 info iobroker host.iobroker2 object system.adapter.sonoff.0.alive created
host.iobroker2 2021-10-24 20:51:40.552 info iobroker host.iobroker2 object system.adapter.sonoff.0.connected created
host.iobroker2 2021-10-24 20:51:40.523 info iobroker host.iobroker2 object system.adapter.sonoff.0.compactMode created
host.iobroker2 2021-10-24 20:51:40.492 info iobroker host.iobroker2 object system.adapter.sonoff.0.cpu created
host.iobroker2 2021-10-24 20:51:40.462 info iobroker host.iobroker2 object system.adapter.sonoff.0.cputime created
