red-contrib-time-photo-files(按照时间存储文件)
在我们做人脸识别,门口动静提醒等等的时候我们需要相关的文件存储到响应的目录里面去,利用以往的节点往往需要拷贝复杂的流程,文件夹和文件名称极易出现错误,所以有了下面的节点。
按照日期把文件存储起来,目录你格式如下:xxxx-xx-xx,例如我今天就是:2019-06-14, 然后文件名字按照:xxxx-xx-xx-xx-xx-xx,例如今天:2019-06-14-20-12-22-(这两个是随机数,防止同1s文件被覆盖),然后后面添加对应的文件格式。
节点信息:
[{"id":"d7878f8a.ae593","type":"tab","label":"流程1","disabled":false,"info":""},{"id":"76580b44.799384","type":"gaode-direction","z":"d7878f8a.ae593","server":"e8313e7d.4f79e","longitude_source":"116.481028","latitude_source":"39.989643","longitude_direction":"80.434446","latitude_direction":"39.989643","city":"","s1":false,"s2":false,"s3":false,"s4":true,"x":449,"y":1175,"wires":[[]]},{"id":"185a06cf.ca6569","type":"inject","z":"d7878f8a.ae593","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":157,"y":1056,"wires":[["76580b44.799384"]]},{"id":"acc08a9d.be1eb8","type":"inject","z":"d7878f8a.ae593","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":497,"y":217,"wires":[["d870db1b.e41238"]]},{"id":"8e2e69c9.a38b88","type":"debug","z":"d7878f8a.ae593","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1125,"y":202,"wires":[]},{"id":"d870db1b.e41238","type":"www-request","z":"d7878f8a.ae593","name":"大方摄像机获取图片","method":"GET","ret":"bin","url":"http://192.168.123.166/cgi-bin/currentpic.cgi","follow-redirects":false,"tls":"","x":761,"y":336,"wires":[["a58a02aa.3a542"]]},{"id":"a58a02aa.3a542","type":"time-photo-files","z":"d7878f8a.ae593","name":"xxx","dirname":"/opt/data","fileType":"jpg","appendNewline":false,"createDir":true,"clear":false,"overwriteFile":"true","encoding":"none","x":941,"y":343,"wires":[["8e2e69c9.a38b88"]]},{"id":"e8313e7d.4f79e","type":"gaode-server","z":"","name":"默认高德key","gaodeKey":"e6296643e3c1bf64508f685c635f1fab"}]
大神 文件目录咋设的,我的据对路径是\192.168.2.244\docker\dl 填了没反应
你的目录路径应该是这样:相片要存在nodered的设置文件夹下,然后对应添加路径。不是向你一样填写ip地址加路径。举个例子,假如我的nr的配置文件放在/xxxx/docker/nodered/dl下面,对应容器的路径是/data/dl,应该添加的是/data/dl
流程中会用到高德的结节是什么用的?我也是大方的摄像头,看了很多教程一直都没截图成功,能否帮帮我?
比如用以下命令ffmpeg -rtsp_transport tcp -i rtsp://10.227
安装了高德的节点,然后再把高德删除了,流程可双正常进行下去,也会产生相关文件,但文件大小都是0,是不是和摄像头设置有关,我用URL可以直接打开摄像头,但前面自动变成HTTPS,不知怎么处理了?
