建议用安卓的手机,小牛注册好像是可以添加个副账号的
苹果的我没有试过但是原理也是一样的,你百度苹果抓包,
只要抓到头部的请求数据,然后在nr里填好就可以看到返回结果了,然后自己把需要的提取出来就好了。提取的GPS位置,要是用百度的话会有偏移,高德就没有问题,
你有做好的流程吗?我可以抓包了。
我只有电池的流程你要的话我可以给你
抓到了包自己弄也方便的就跟API一样然后自己写写就好了
好啊、借鉴借鉴
字数补丁
[{"id":"9fe7357e.834d18","type":"http request","z":"69e4513c.dcbb8","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":400,"y":1400,"wires":[["e5fd7b4.1d5f588"]]},{"id":"e5fd7b4.1d5f588","type":"json","z":"69e4513c.dcbb8","name":"","property":"payload","action":"","pretty":false,"x":540,"y":1400,"wires":[["1eff83eb.368efc","1f77456f.d11e0b"]]},{"id":"1eff83eb.368efc","type":"debug","z":"69e4513c.dcbb8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":710,"y":1340,"wires":[]},{"id":"1f77456f.d11e0b","type":"function","z":"69e4513c.dcbb8","name":"转义信息","func":"var i = msg.payload.data.batteries.compartmentA.batteryCharging ;\nvar k = msg.payload.data.estimatedMileage;\nif (i!=0){\n var message =('牛牛的电量有百分之'+i+'可以行驶'+k+'公里');\n} else {\n var message=('牛牛,没有安装电池噢')\n}\n\nmsg.payload = {};\nmsg.payload.data = {\"message\":message};\nreturn msg;;","outputs":1,"noerr":0,"x":700,"y":1400,"wires":[["6429c42a.24488c"]]}]
能放进TXT吗?复制后有问题
在看一下,我fix了一下格式
花神,考虑下能不能把小米的万能遥控接入?
可以了~~~
字数补丁
没想法,没设备,也不知道怎么玩
你好, 群晖 usb蓝牙已,已经可以用群晖原始套件播放音乐了
想请问如果实现 hass音箱功能。并阅读文字。谢谢
美的消毒柜接入!
1、接入中控科技的门禁设备,摄像头人脸识别开门。
2、摄像头视频流实时识别人脸。
海尔空调的接入、控制及反馈状态
海信空调的接入。。。
萤石云台控制的帖子咋找不到哈?
问了也不指个路,征集个啥哟,无语
