table { font-family: monospace; font-size: 14px; } .info { background: white; } .type { font-weight: bold; } .silly { background: #b3b3b3; } .debug { background: lightgray; } .warn { background: #ffdb75; color: white; } .error { background: #ff6a5b; }
2020-09-16 05:30:02.562 - info: admin.0 Repository received successfully.
2020-09-16 05:30:43.331 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:32:41.357 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:33:00.913 - info: iobroker add admin --host aml
2020-09-16 05:33:02.616 - info: iobroker host.aml create instance admin
2020-09-16 05:33:02.629 - info: iobroker host.aml object admin.1.connected created
2020-09-16 05:33:02.661 - info: iobroker host.aml object admin.1 created
2020-09-16 05:33:02.693 - info: iobroker host.aml object admin.1.info created
2020-09-16 05:33:02.727 - info: iobroker host.aml object system.adapter.admin.upload created
2020-09-16 05:33:02.759 - info: iobroker host.aml object system.adapter.admin.1.outputCount created
2020-09-16 05:33:02.791 - info: iobroker host.aml object system.adapter.admin.1.inputCount created
2020-09-16 05:33:02.823 - info: iobroker host.aml object system.adapter.admin.1.uptime created
2020-09-16 05:33:02.855 - info: iobroker host.aml object system.adapter.admin.1.memRss created
2020-09-16 05:33:02.887 - info: iobroker host.aml object system.adapter.admin.1.memHeapTotal created
2020-09-16 05:33:02.919 - info: iobroker host.aml object system.adapter.admin.1.memHeapUsed created
2020-09-16 05:33:02.951 - info: iobroker host.aml object system.adapter.admin.1.cputime created
2020-09-16 05:33:02.982 - info: iobroker host.aml object system.adapter.admin.1.cpu created
2020-09-16 05:33:03.016 - info: iobroker host.aml object system.adapter.admin.1.connected created
2020-09-16 05:33:03.048 - info: iobroker host.aml object system.adapter.admin.1.alive created
2020-09-16 05:33:03.101 - info: host.aml object change system.adapter.admin.1
2020-09-16 05:33:03.119 - info: host.aml instance system.adapter.admin.1 started with pid 3233
2020-09-16 05:33:03.124 - info: iobroker host.aml object system.adapter.admin.1 created
2020-09-16 05:33:03.163 - info: iobroker exit 0
2020-09-16 05:33:05.947 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:33:06.028 - info: admin.1 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.admin, node: v8.16.0
2020-09-16 05:33:06.103 - info: admin.1 requesting all states
2020-09-16 05:33:06.108 - info: admin.1 requesting all objects
2020-09-16 05:33:06.111 - info: admin.1 Request actual repository…
2020-09-16 05:33:06.847 - info: admin.1 received all states
2020-09-16 05:33:09.910 - info: admin.1 received all objects
2020-09-16 05:33:10.113 - error: admin.1 port 8081 already in use
2020-09-16 05:33:10.115 - info: host.aml Update repository “latest” under “http://download.iobroker.net/sources-dist-latest.json”
2020-09-16 05:33:10.160 - error: host.aml instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
2020-09-16 05:33:10.160 - info: host.aml Do not restart adapter system.adapter.admin.1 because desired by instance
2020-09-16 05:33:18.301 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:33:32.216 - info: host.aml object change system.adapter.admin.1
2020-09-16 05:33:32.218 - info: host.aml “system.adapter.admin.1” disabled
2020-09-16 05:33:34.982 - info: iobroker del admin.1
2020-09-16 05:33:36.378 - info: iobroker Delete adapter “admin.1”
2020-09-16 05:33:36.414 - info: iobroker host.aml Counted 1 instances of admin.1
2020-09-16 05:33:36.429 - info: iobroker host.aml Counted 1 channels of admin.1
2020-09-16 05:33:36.447 - info: iobroker host.aml Counted 16 states of admin.1
2020-09-16 05:33:36.454 - info: iobroker host.aml Counted 5 states (io.admin.1.) from states
2020-09-16 05:33:36.471 - info: iobroker host.aml Counted 11 states (system.adapter.admin.1.) from states
2020-09-16 05:33:40.109 - info: iobroker host.aml Counted 1 objects of admin.1
2020-09-16 05:33:40.111 - info: iobroker host.aml Deleting 19 object(s).
2020-09-16 05:33:40.195 - info: host.aml object change system.adapter.admin.1
2020-09-16 05:33:40.196 - info: host.aml object deleted system.adapter.admin.1
2020-09-16 05:33:40.200 - info: iobroker host.aml Deleting 16 state(s).
2020-09-16 05:33:40.290 - info: iobroker exit 0
2020-09-16 05:33:44.870 - info: host.aml object change system.adapter.admin.0
2020-09-16 05:33:44.873 - info: host.aml stopInstance system.adapter.admin.0
2020-09-16 05:33:44.873 - info: host.aml stopInstance system.adapter.admin.0 killing pid 2728
2020-09-16 05:33:44.877 - info: admin.0 terminating http server on port 8081
2020-09-16 05:33:44.894 - info: admin.0 terminating http server on port 8081
2020-09-16 05:33:44.919 - info: host.aml instance system.adapter.admin.0 terminated with code 0 (OK)
2020-09-16 05:33:47.401 - info: host.aml instance system.adapter.admin.0 started with pid 3288
2020-09-16 05:33:50.138 - info: admin.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.admin, node: v8.16.0
2020-09-16 05:33:50.209 - info: admin.0 requesting all states
2020-09-16 05:33:50.213 - info: admin.0 requesting all objects
2020-09-16 05:33:50.215 - info: admin.0 Request actual repository…
2020-09-16 05:33:50.935 - info: admin.0 received all states
2020-09-16 05:33:53.213 - info: admin.0 received all objects
2020-09-16 05:33:53.394 - info: admin.0 http server listening on port 8081
2020-09-16 05:33:53.394 - info: admin.0 Use link “http://localhost:8081” to configure.
2020-09-16 05:33:53.521 - info: host.aml Update repository “latest” under “http://download.iobroker.net/sources-dist-latest.json”
2020-09-16 05:33:54.936 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:33:57.871 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:33:59.732 - info: admin.0 Repository received successfully.
2020-09-16 05:34:44.998 - info: iobroker add discovery --host aml
2020-09-16 05:34:48.646 - info: iobroker NPM version: 6.4.1
2020-09-16 05:34:49.585 - info: iobroker npm install iobroker.discovery@2.3.11 --production --save --prefix “/opt/iobroker” (System call)
2020-09-16 05:36:00.206 - info: iobroker prebuild-install
2020-09-16 05:36:00.217 - info: iobroker WARN install No prebuilt binaries found (target=8.16.0 runtime=node arch=arm64 libc= platform=linux)
2020-09-16 05:36:28.514 - info: iobroker host.aml install adapter discovery
2020-09-16 05:36:28.547 - info: iobroker got /opt/iobroker/node_modules/iobroker.discovery/admin
2020-09-16 05:36:28.574 - info: iobroker upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
2020-09-16 05:36:28.757 - info: iobroker upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
2020-09-16 05:36:28.856 - info: iobroker upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
2020-09-16 05:36:28.916 - info: iobroker upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
2020-09-16 05:36:28.976 - info: iobroker upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
2020-09-16 05:36:29.056 - info: iobroker upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
2020-09-16 05:36:29.146 - info: iobroker upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
2020-09-16 05:36:29.270 - error: iobroker host.aml Invalid version of “js-controller”. Installed “1.5.14”, required ">=2.0.0
2020-09-16 05:36:29.287 - info: iobroker exit 30
2020-09-16 05:36:37.442 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:38:12.154 - info: host.aml received SIGTERM
2020-09-16 05:38:12.157 - info: admin.0 terminating http server on port 8081
2020-09-16 05:38:12.173 - info: admin.0 terminating http server on port 8081
2020-09-16 05:38:12.227 - info: host.aml instance system.adapter.admin.0 terminated with code 0 (OK)
2020-09-16 05:38:12.229 - info: host.aml All instances are stopped.
2020-09-16 05:38:12.364 - info: host.aml terminated
2020-09-16 05:42:51.232 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:43:21.890 - info: iobroker add discovery --host aml
2020-09-16 05:43:23.341 - info: iobroker host.aml install adapter discovery
2020-09-16 05:43:23.366 - info: iobroker got /opt/iobroker/node_modules/iobroker.discovery/admin
2020-09-16 05:43:23.393 - info: iobroker upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
2020-09-16 05:43:23.577 - info: iobroker upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
2020-09-16 05:43:23.674 - info: iobroker upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
2020-09-16 05:43:23.736 - info: iobroker upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
2020-09-16 05:43:23.798 - info: iobroker upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
2020-09-16 05:43:23.878 - info: iobroker upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
2020-09-16 05:43:23.955 - info: iobroker upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
2020-09-16 05:43:24.075 - error: iobroker host.aml Invalid version of “js-controller”. Installed “1.5.14”, required ">=2.0.0
2020-09-16 05:43:24.094 - info: iobroker exit 30
2020-09-16 05:43:58.540 - info: admin.0 successful connection to socket.io from ::ffff:192.168.31.181
2020-09-16 05:44:07.613 - info: iobroker upgrade admin
2020-09-16 05:44:10.367 - error: iobroker Invalid version of js-controler. Required >=2.0.0
2020-09-16 05:44:10.388 - info: iobroker exit 0
2020-09-16 05:47:13.261 - info: iobroker upgrade admin
2020-09-16 05:47:16.160 - error: iobroker Invalid version of js-controler. Required >=2.0.0
2020-09-16 05:47:16.180 - info: iobroker exit 0
