这个流对摄像机没有要求吗,是不是所有的摄像头都可以这么设置
LIB下放了这几个文件:libarcsoft_face_engine_jni.so libarcsoft_face_engine.so libarcsoft_face.so
启动提示这个,然后一直重启老哥帮忙看看。
:: Spring Boot :: (v2.1.6.RELEASE)
2020-09-04 22:43:05.578 INFO 6 — [ main] m.k.f.FaceRecognitionApplication : Starting FaceRecognitionApplication v0.0.1-SNAPSHOT on b74235769831 with PID 6 (/app/face_recognition.jar started by root in /)
2020-09-04 22:43:05.591 INFO 6 — [ main] m.k.f.FaceRecognitionApplication : No active profile set, falling back to default profiles: default
2020-09-04 22:43:07.718 INFO 6 — [ main] o.s.b.w.embedded.tomcat.TomcatWebServer : Tomcat initialized with port(s): 8080 (http)
2020-09-04 22:43:07.788 INFO 6 — [ main] o.apache.catalina.core.StandardService : Starting service [Tomcat]
2020-09-04 22:43:07.792 INFO 6 — [ main] org.apache.catalina.core.StandardEngine : Starting Servlet engine: [Apache Tomcat/9.0.21]
2020-09-04 22:43:07.913 INFO 6 — [ main] o.a.c.c.C.[Tomcat].[localhost].[/] : Initializing Spring embedded WebApplicationContext
2020-09-04 22:43:07.914 INFO 6 — [ main] o.s.web.context.ContextLoader : Root WebApplicationContext: initialization completed in 2222 ms
2020-09-04 22:43:10.723 INFO 6 — [ main] m.k.f.s.impl.FaceEngineServiceImpl : haoliang 微信图片_20200901204612.jpg load success
2020-09-04 22:43:12.797 INFO 6 — [ main] m.k.f.s.impl.FaceEngineServiceImpl : haoliang 微信图片_20200901204622.jpg load success
2020-09-04 22:43:13.052 INFO 6 — [ main] o.s.s.concurrent.ThreadPoolTaskExecutor : Initializing ExecutorService ‘applicationTaskExecutor’
2020-09-04 22:43:13.409 WARN 6 — [ main] o.s.b.a.f.FreeMarkerAutoConfiguration : Cannot find template location(s): [classpath:/templates/] (please add some templates, check your FreeMarker configuration, or set spring.freemarker.checkTemplateLocation=false)
2020-09-04 22:43:13.444 INFO 6 — [ main] o.s.s.c.ThreadPoolTaskScheduler : Initializing ExecutorService ‘taskScheduler’
2020-09-04 22:43:13.528 INFO 6 — [ main] o.s.b.w.embedded.tomcat.TomcatWebServer : Tomcat started on port(s): 8080 (http) with context path ‘’
2020-09-04 22:43:13.534 INFO 6 — [ main] m.k.f.FaceRecognitionApplication : Started FaceRecognitionApplication in 9.168 seconds (JVM running for 9.728)
2020-09-04 22:43:14.769 INFO 6 — [nio-8080-exec-1] o.a.c.c.C.[Tomcat].[localhost].[/] : Initializing Spring DispatcherServlet ‘dispatcherServlet’
2020-09-04 22:43:14.770 INFO 6 — [nio-8080-exec-1] o.s.web.servlet.DispatcherServlet : Initializing Servlet ‘dispatcherServlet’
2020-09-04 22:43:14.786 INFO 6 — [nio-8080-exec-1] o.s.web.servlet.DispatcherServlet : Completed initialization in 16 ms
http://host:9090,提示这个:
Whitelabel Error Page
This application has no explicit mapping for /error, so you are seeing this as a fallback.
Sat Sep 05 07:30:38 CST 2020
There was an unexpected error (type=Not Found, status=404).
No message available
同上,怎么回事啊?
群晖docker安装YOLO,不知道能不能类似人脸识别功能,用nr离线识别是否有人, 然后执行动作。
看下面例子使用很简单,实际docker安装后不知道怎么调用识别图片呢
还有个问题:你们的摄像头图片怎么取到的,用的带抓拍功能摄像机么? (我 现在用onvif组件解决了,目前摄像机品牌不受限制了)
使用百度在线的分析都是好的了。虹软这个还是有问题。
目前出了3个错误,
1、第一张图:一个是GLICBXX,系统缺少依赖,这个不用装整套gcc吧(这个问题解决了,更换了libstdc文件,从另一个服务器下载的)
2、第一张图:一个是创建目录,但是我在docker 里用mkdir测试,是可以建目录的(读目录报的错,不知道怎么回事,,貌似没影响)
3、第二张图:暂未解决
